Overunity.com Archives
Solid States Devices => solid state devices => Topic started by: froarty on December 05, 2008, 01:13:27 PM
Title: Pyramids sort virtual particles using casimir force
Post by: froarty on December 05, 2008, 01:13:27 PM
calcium found in limestone blocks of coral or pyramid is a metal, even as microscopic powder it forms cavities equivalent to metal casimir plates, gas molecules trapped in these cavities see the reducton in virtual particles as a widening of the dimension of time in the cavity. this allows them to rotate into a normally impossible orientation that Dr Mills of Black Light Power has coined "hydrinos" (at least for hydrogen but any gas will do) these "twisted" molecules will simply untwist upon exiting the portion of the cavity meeting casimir geometry (<2nm) --HOWEVER-- if they form molecules while twisted the molecule remains twisted even after exiting the "plates" back into normal space - at this point they are surrounded by stessed virtual particles trying to push the atoms back into normal orientation but unable to overcome the covalent bond. the molecule is now oriented permanently away from normal space and is  larger than the 1 nuclei average width of the "present" as infered by the uncertainty principle (you can not know both the electrons momentum and location unless you are standing on the electron which is being moved smoothly from 1 position to another by displacement in the virtual particle stream) this tells us that electrons are already knee deep in time and infers the time width of the "present". We must agitate these trapped molecules into motion so they claw into the fabric of space-time and resist relative motion to the time stream up or down - sideways however I would not be surprised if a limestone block could be moved "1 bow shot" or 200 feet exactly according to legend - the block must be wedged up, then agitated either magnetically, electrically or sonicly and then remove the wedges and quickly scoot the block horizontally. (let me know if it works:_))                 http://www.byzipp.com/animation.htm
this theory also supports the shape of the pyramid as we sink upside down into the sea of time the virtual particles approach us like an air mass approaches the front of an aircraft -smaller VP go thru the nuclei mesh and larger go around to form a complex wake pattern interposing itself between the self repelling electrons and the protons they are trying to reach at their nuclei. If they must squeeze down and around geometrically expanding layers of "twisted" molecules and casimir stress fields while permeating the pyramid then the normally straight line path of the time stream can be thinned and widened as it permeates through more and more of these limestone casimir cavities. this even lends credability to the celestial observation tunnels as ancient gravitational engineers sought to utilize casimir lined channels
to leverage celesstial gravity agaist teresstrial
Title: Re: Pyramids sort virtual particles using casimir force
Post by: TechStuf on December 05, 2008, 01:24:18 PM
Quotethis even lends credability to the celestial observation tunnels as ancient gravitational engineers sought to leverage the delta in gravitational pressure theses microscopic fields could generate.
Sure, that's exactly what they did.  The slaves leveraged alot of things alright, but 'gravitational pressure deltas' weren't among them.
Perhaps Vimana powered by Baghdad batteries were also employed to get the job done on time and on spec, as well?
TS
Post by: froarty on December 05, 2008, 01:37:10 PM
give me 2 minutes to change your mind? read this http://byzipp.com/energy/
Post by: TechStuf on December 05, 2008, 02:05:27 PM
Oh, I'm not doubting the realities & possibilities of the Casimir force one bit.  Just the ancient gravitational engineers levaraging gravity pressure deltas, part.
Peace,
TS
Post by: TechStuf on December 05, 2008, 02:29:39 PM
This just in....BUGS BUILT PYRAMIDS......
http://www.youtube.com/watch?v=_ChsZUwqTeE
Although I'm sure there is a grain of truth to Grebennikov's account, too many incongruities make it very unlikely that he or our "distant" ancestors reduced such concepts or principles to practice at all.  Much less, in the ways described.
TS
Post by: froarty on December 05, 2008, 08:33:04 PM
couple more clues for harnessing limestone -calcium metal  casimir plates, casimir plates will normally self aggregate unless braced apart or formed by chemical action such as leaching after the fact like sodium hydroxide used to make raneynickel  in BlackLight Powers catalyst discovery. In a limestone slurry the cavities will orient themselves for minimum resistance to time-gravity. this means the block should be stood on end so the microscopic cavities present the more resistant profile. In the case of Coral Castle the coral was created by organisms depositing calcium that again took the path of least resistance. the test will be to agitate the block so these molecules drag out as far as possible on either side of the "Present" time frame providing a frictional brake in the vertical gravity-time direction but allowing the block pendular motion in the horizontal.  -Sounds crazy I know but if Dr Mills' hydrino is for real then all the rest follows logical progression! simple test would be a hydraulic jack to lift, agitate the block with moving fields, sound, heat or combo then lower the jack -maybe whole aparutus on a scale to test for marginal results while we dial it in?
Post by: TechStuf on December 05, 2008, 10:00:23 PM
The following is a true account of one of my experiences:
http://www.rense.com/general54/babalc.htm
So, I'm with you as far as matter being induced to higher energy states by the right frequency interactions.  I think the evidence is compelling that anomalous gravitic interactions have taken place in various independent 'labs'.  Of course the evidence is also compelling that TPTB have gone far beyond that as a result of such discoveries.
TS
Post by: froarty on December 05, 2008, 10:48:09 PM
don't know what TPTB stands for but I agree it is unlikely to have gone undiscovered for so long -granted you have to have metal cavities <2nm, to produce hydrinos like Black Light Power you need open cavities, to use for friction with the miniscus of our 1 nuclei wide gravity-time frame (Present) you need an enclosed cavity with an excitable gas such that we can agitate a portion of the atms to form "twisted" covalent bonds and then circulate them around like oversized pincusions where the electron -needles are catching a ride on the overall downward motion of gravity -time. I'm thinking maybe still 9.8 meters per second...but NOT squared because you keep starting over everytime the needles prick the fabric.
Post by: TechStuf on December 05, 2008, 11:43:59 PM
We conspiracy nuts like our acronyms...lol....it stands for The Powers That Be.  I take it then, you have read Tesla's ideas on the "solidification of the aether"?
TS
Post by: froarty on December 06, 2008, 12:01:03 PM
ok, I am not sure if we are talking conspiracy yet- my theory has been emailed to hundreds of physics and some geology faculty all over the world in the last 10 days since I realized the "hydrino" theory suggested by Dr Mills, and two doctors in a May 8 patent from caltech is only a "working mans" theory that allows for chemically rectifying energy from gravity-time flow through the "present" or as CalTech patent explains using casimir force to reduce the hydrogens atoms' zero state below minimum (already extremly controversial).they missed what I think was clear -that atoms passing thru the plates will simply rotate in and out of what they call subzero state and that the atoms must form covalent bond while passing thru the plates to retain what I term"twisted" orientation outside the plates where it can be harnessed as fuel. I agree with classic physics that an electron orbit has a minimum radius and can not become "sub zero" My theory is that they twist on the time axis only appearing smaller from the perspective of normal space. My theory makes numerous unexplained anomalies suddenly fit a plausible pattern. http://www.blacklightpower.com/ in Cranburry NJ has 60 million in investment funds and with their recently validated (oct 25,2008) product by Rowan University labs want to sell us preloaded fuel cells where small amounts of hydrinos are contained in the skeletal catalyst Rayney Nickel and heated in a reactor. the amount of energy released was repeatedly hundreds of times greater than the amount of hydrogen added to the catalyst. they were unable to detect any change or degredation of the catalyst despite repeated cycling over the summe/fall investigation. My point is that anyone should be able to produce their own hydrinos using simple hho kits modified with skelatal catalysts to convert hydrogen to hydrinos - when the covalent bond is cut by combustion the virtual particles act in an organized fashion to push the twisted atoms back into normal orientation - proving that we can chemically force the normally chaotic nature of virtual particles (AKA vacumn flucuations) to organize and do harnessable work. it also proves we are not getting something for nothing -we know that we are moving thru a sea of virtual particles and that these particles must squeeze thru and around all nuclei as it passes from the future to the past on the time axis. black light has simply found a "casimir / chemical: principle to rectify some of this energy. I have made a simple flash animation of my theory here http://www.byzipp.com/animation2.htm - the page has a menu with the proposal, casimir force history, and links to the recent patents and lab validations.
               the additional importance of this discovery cannot be understated, the "open" casimir cavities of skeletal catalysts mean we can "process" twisted molecules to form an entirely new branch of chemistry and physics. the possibility of multiple stage casimir chemistry as the product of each plate appear smaller from our perspective than the inputs of each preceding stage means that super twisted molecules become possible. The "twisted" molecules inside "closed" cavities as I have been explaining offer plausible explanation for legends of coral castle and pyramid block if the calcium metal forms casimir geometry. The trapped gas in these cavities will have a certain proportion of twisted molecules settled into an orientation of least resistance with the gravity -time field. Agitating these molecules caused their twisted dimension to oscilate like oversized pincusions between two curtains (future & past). propped up before agitation the "curtains" would allow for pendular motion but restrict upward or downward motion. The geometry of the pyramids also suggests intelligent manipulation, As the gravity-time field "crosses" the present on the time axis we feel the virtual particles permeate our 1 nuclei wide temporal dimension. from the temporal dimension this 1 nuclei wide fabric folds almost infinetly to trace out what we perceive as reality in much the way an electron beam traces out a picture on a TV screen. this 1 nuclei wide folded mesh implies the pyramid shape is sorting and steering virtual particles like an aircraft nose cone  steers air  around the plane, the larger virtual particles (gravity) are steered around the the casimir cavities through subsequent layers of the pyramid redirecting them to the outside of the pyramid, the smaller virtual particles that normally permeate the nuclei instead of going around and which we experience as time do fit inside the casimir cavities are
allowed to concentrate on the centerline of the pyramid. I would suggest any serious pyramid investigations "close off" the pyramid openings with casimir plates in the form of limestone blocks. an open pyramid corridor will immediately relieve any virtual particle differential, the celesstial observation shafts are probably another clue to VP manipulation that I am still chewing on.
Post by: TechStuf on December 06, 2008, 01:27:31 PM
You speak as though you've applied your theories to the workbench....what real world observations have you made that lend promise to your assertion that time is, in effect, a curtain....or membrane of sorts?   As one can readily ascertain, many a discovery has been made by apparent 'accident' resulting in large scale exploitation of principles which often remain largely unknown.
In other words, one is neither needed nor required to fully understand a concept before being able to implement such.
This is the bread and butter of the independent hands on researcher.
Have you had any successes reducing your concepts to practice?   John Hutchison from Canada apparently had some successes by applying directed energies to matter.... similar to the Kowsky Frost research.
TS
Post by: Tigrotto on December 09, 2008, 03:21:10 AM
Hi to all,
1Gramm of experience is more than tons of theory!
I invite all of you to experience the accumulator charging under the pyramid!
I did it, I repeat, but it miss me something to go ahead... maybe ...tons of theory!
even if I'm a physicist!
By the way: how many of you tried to charge accumulators under pyramid?
I did it mainly with batteries... not  accumulators! Looks strange, but if one plays with pyramids for years will understand why.
Any aid is wellcome and I'm ready to put on the table all my experimental results for all of you, even if skeptics among us!
Tigrotto
(traderfx05@yahoo.com.au)
Post by: froarty on December 09, 2008, 01:44:44 PM
Trigo,
I am only 6 weeks in and so far just electrolysis product of hydrogen and ox, but gathering lab stuff includes real nickel, crystal drano, scope dig meter, and color bar generator from my past, need to make non ferrous balance and a simple AC electro stat force as an agitator - also want to use mag tape eraser, heater and sonic as other cavity agitators . You know what I'll just paste last email to my brother minus the attachements but first let me paste my latest contribution of what I believe we are trying to tap...http://www.byzipp.com/animaTime.htm
to brother tom...Possible Paper/experiment:
The case for "open" Casimir cavities in skeletal metal to produce hydrinos. Use Black Light Power and Rowan verification as evidence.
Investigate Electroplate as home made Rainy Nickel plating , to use as skeletal catalyst hydrogen electrode paste direct in water -attempt 1 step to hydrino electrolysis! also investigate other skel cats that are less restricted to residential labs for test.
a case for "closed" Casimir cavities to sort virtual particles by size
limestone, coral, Stonehenge, pyramid block may all contain microscopic Calcium metal Casimir cavities & trapped gas that may become twisted when agitated? Even without agitation structures such as limestone pyramids would restrict larger virtual particles steering them thru the layers toward the outer face while smaller VP are free to pass thru Casimir cavities to slowly concentrate on the centerline of the pyramid much like the nose cone of an air craft. *Test home made limestone block with plastic encased test objects embedded (duplicate non limestone blocks as controls --watches-- wet copper - even gold which has legend re some sort of oil and white powder formation) â€"simple instrumentation to compare resistance/weight/resonance waveform before and after. Need Cal-tech & British citation regarding 1.7THZ (above 1.7 =time, below = gravity OR small Virtual particles we perceives as time & permeate our nuclei, large VP are displaced by nuclei and we sense as gravity)
Agitators to investigate = heat, alternating electrostatic field, mag field,  sonic.  Legend regarding pyramid blocks propped with papyrus then agitated then quickly remove papyrus and scoot block 1 bow shot apx 200 feet if true would give relative measure of relative speed space time squeezes thru the what we would perceive as a 2d grid as viewed from the time axis on our present moment in time. The point of the legend is that the block leverages pendular motion of space time fabric while "twisted" molecules employ "frictional braking" to lock the blocks vertical position -the block would also be harder to lift! This means space time moves extremely slowly relative to the astronomical numbers we consider of celestial bodies thru normal space - If rumors about nasa space Tether video were true the unexplained width of the 12 mile tether and the saucer shapped "space debris" moving in front of and behind the tether take on a whole new signifigance. Possible time "frame dragging" and we already know large mass = gravitational lensing so the high voltage on a 12 mile tether with the shuttle camera sighted perpendicular down thru the entire length of the field is very likely a temporal lens - see YouTube tether video.
agitators: electrostatic field oscillator use alternating foam metal pads on either side of plastic motor driven wheel, foam will gen charge, plastic will form dielectric and all metal pads on either side will be grounded together. A test gas in bottle will see alternating static charges when hung parallel to the bottom of this spinning plate. Note normal electrostatic attraction and repulsion will need to be eliminated by removal of agitator before collecting any data -pass or fail it will be fun:_) and hopefully make a good paper ?
Agitators continued:  mag field use tape degausser, heat,
Investigate nitrogen and ox electrode and capture gas to diffuse thru skelpowder. Again test for other twisted molecules.
Teslas’ claim of solidification of ether using electrostatic may be enhanced on "twisted" molecules if his theory was dependent on the small population of normally occurring twisted molecules.
Paper referred to
http://www.calphysics.org/zpe.html
In one paragraph they talk about (wave fragments),
How could such an enormous energy not be wildly evident? There is one major difference between zero-point electromagnetic radiation and ordinary electromagnetic radiation. Turning again to the Heisenberg uncertainty principle one finds that the lifetime of a given zero-point photon, viewed as a wave, corresponds to an average distance traveled of only a fraction of its wavelength. Such a wave ''fragment'' is somewhat different than an ordinary plane wave and it is difficult to know how to interpret this.
And later on they say
Recent work by Christian Beck at the University of London and Michael Mackey at McGill University may have resolved the 120 order of magnitude problem. In that case dark energy is nothing other than zero-point energy. In Measureability of vacuum fluctuations and dark energy and Electromagnetic dark energy they propose that a phase transition occurs so that zero-point photons below a frequency of about 1.7 THz are gravitationally active whereas above that they are not. If this is the case, then the dark energy problem is solved: dark energy is the low frequency gravitationally active component of zero-point energy.
-----Original Message-----
Sent: Monday, December 08, 2008 3:16 PM
To: Roarty, Francis X
Subject: RE: cable tv
fran,
no problema...doris is top priority now!
Tom
--- On Mon, 12/8/08, Roarty, Francis X <francis.x.roarty@lmco.com> wrote:
> From: Roarty, Francis X <francis.x.roarty@lmco.com>
> To: troarty@yahoo.com
> Date: Monday, December 8, 2008, 1:19 PM
> Tom,
>      Doris was in real bad shape Friday and I haven't been
> home yet
> to leave the cable material and crimps...sorry - I totally
> forgot to
> tell you. I will leave the stuff there this afternoon when
> I stop home
> to restock. I may have to set up my lab at Doris' house
> so I can keep an
> eye on her. I did start organizing already in my basement
> but really not
> too far along.
> Fran
> From: tom roarty [mailto:troarty@yahoo.com]
> Sent: Saturday, December 06, 2008 10:03 AM
> thanks fran...let me know when I can come over...I'll
> pick up the cable
> crimper plus see how things are progressing with the
> experiment.
Post by: spacetrax on December 10, 2008, 04:30:32 AM
Hi,
have you had any success with Thomas Trawoegers pyramid?
My modell was NOT working.
Cheers!
Quote from: Tigrotto on December 09, 2008, 03:21:10 AM
Hi to all,
Tigrotto
Post by: froarty on December 10, 2008, 10:58:00 AM
to reply to my assertion that time is a "curtain or membrane" I was refering to the perspective from the time axis, whenever you have a plate immersed in a medium you have at least 2 boundaries form on either side of the plate. All I am saying is that all matter in the "present" forms the familiar 2D mesh you see in numerous texts and papers representing the "NOW" and that this matter forms a boundary condition with the sea ahead of it and behind it just like a mesh sinking in water.
