Please bare with me. I am new here, and I'll have to learn my way through this forum.
Please look at the attached drawing which is self-explanatory and tell me if you see what I see.
The drawing represent two wheels: one small wheel, with diametrically magnetised permanent magnets, lining its outer rim, with their north (N) and south (S) poles fixed as shown, freely rotable on its fixed axle. One larger cylindrical wheel, with diametrically magnetised permanent magnets lining between its inner and outer rims.
The small wheel rotates on its fixed axle.
The larger wheel rests and rotates on the outer rim of the small wheel.
NOW!
I see the larger wheel being pulled to the smaller wheel on the counter-clockwise side by the attraction of opposite poles of magnets and being pushed away from the smaller wheel on the clockwise side by the repulsing of like poles, forcing smaller wheel to be in a continuous unbalanced state and rotate continuously.
Do you see what I see???
Even if it seems constantly in an unbalanced state, it will eventually come to rest in a state, where least energy is needed. And there is plenty of possibilities in this setup. I'm sorry, but this device will not work in my opinion :(
Interesting design. I think only experiments can prove or disprove its usefulness, at the moment I cannot 'see' any negative thoughts in my mind against its magnetic operation. Will consider more pondering on it later.
Very Interesting Design.
Yeah, I too think that the best way to prove or disprove whether it works is to build one & try it out.
I agree it could looks like it may run if it can be started. I do see possible stiction points but I think it's really hard to say without giving it a try. Looks fairly easy to build if you have the diamagnetic magnets.
Quote from: e2matrix on June 06, 2010, 09:05:39 PMit's really hard to say without giving it a try
No, it's not hard to say that it won't work, if you've messed around with magnets before. If you don't believe I'd suggest that you buy 50 magnets for a total of 20$ and try out multiple arrangements yourself...
I thank you all gentlemen for your replies.
I would like many more forum members to reply and let me know what they see in my concept ( A very simple concept).
Tell me honestly what you see, good or bad. It won't hurt me.
I see the the wheels in the drawing in a BALANCED state (as if held at rest at this position). But looking closely at its setup, you will feel that the small wheel must get unbalanced immediately (when released from held rest position) because of the magnets attracting and repelling actions.
The small wheel will then rotate clockwise, because of the additional torque provided by the larger wheel resting and moving further from the axle of the smaller wheel on that clockwise side.
I see the actions of the magnets to continue. I see the rotations of the two wheels to continue.
I DO NOT see anything in this set up to act, to counter this rotation once started. Not even FRICTION.
Of course, the efficiency of my device will depend on (1) the strength and weight of the magnets,(2) the size of the wheels and (3) the weight of the larger wheel which will provide the required torque.
N.B: Further efficiency can be attained with magnets lined up throughout the circumference of both wheels.
Now!
How many of you, good members of this esteemed forum, see what I see?
I thank you in advance for your replies.
Please remember, your replies can be positive or negative views. I will appreciate them. I just want to hear from you.
Raj Balkee
Mauritius
Just a quick passing thought!!!
If the wheels won't run, they must keel to a stop position.
Where will be that 'Keel' position?
Certainly not the positions of the wheels as in the drawing. Here the magnets are ready to act, pull and push to start a motion of the wheels.
Where will be the rest position of the wheels if they wont't run???
Hi Ray,
I think your setup can work as you describe. I 'went through' on it in my mind and have not found a state where the rotation could stop due to sticky points. Of course there are sticky points.
The biggest sticky point is whenever two magnets on the different wheels are just passing in front of each other as you can see in the drawing at the 12 o'clock position on the big wheel but this sticky point is always defeated by two attract and two repel effects of the neighbouring magnets.
The other sticky points are much much smaller than the big one just mentioned and they depend mainly on the diameter of the small wheel with respect to the big wheel. The small sticky points (that are not at the 12 o'clock position) are also compensated for by the attract and repel forces, there is very little residual motion-to-counterforce remains that is also overcome by the main two attract and repel forces mentioned earlier.
Do you have practical result with this setup or you just figured it out without any tests? Maybe you have some hint on the ratio of the outside diameters of the two wheels? They are important of course. Suppose the big wheel has a 30cm OD, then the small wheel should have slightly less than 15cm OD or around the half OD of the big wheel?
rgds, Gyula
Hello Gyula,
I would have already built a working device, but for lack of readily available materials, like special magnets in my tiny Island Country, I have not been able to do so.
I have carried out partial initial test to check basic concept of my device, using magnets from car windscreen wiper motor, and my tests were conclusive.
I have no doubt that with proper cylindrical diametrically magnitised magnets, my device will work perfectly. At least this is what I see right now!.
I have no knowledge of electromagnetism. Thus I do not have any clue to any rpm that the wheels
will have and least of all, I do not have a clue to any power output my device may or may not give.
All I see is that my device will run.
That's all I want. Just show a running device for now.
I know many of you gentlemen have far more facilities in your countries to built devices like mine. Needless to say, how much I would appreciate if any of you, good Samaritan, will try to build and test my device and let us all know the outcome of his endeavour. I know it will cost a few dollars, as one of our friends has mentioned earlier, but I believe it will be money well spent, as it will show us something we don't know yet.
Once again, I thank you, and all other friends on this forum, for taking their time and effort to contribute on my topic in here.
Raj
Hi Raj,
Thanks for your answers. I wonder what is your take on the diameter ratio of the wheels? I 'feel' the small wheel may have a maximum OD of half of that of the big wheel.
rgds, Gyula
Hello again Gyula,
Initially, the diameter of the smaller wheel (rotable on its fixed axle) is half the diameter of the inside rim of the larger wheel, so as to make the magnet at the 10.30 o'clock position on the larger wheel to come right on top of the magnet at the 9 o'clock position on the smaller wheel when both magnets pass the 12 o'clock position on the smaller wheel.
But things can be made easier by lining magnets throughout the whole of circumference of both wheels. Then the difference in diameters of the wheel will only affect the torque that the larger will provide to the smaller wheel, which will then affect the rpm and power output of the device.
I hope you can see what I can see.
Regards.
Raj
Ok, and one more thing: why did you give title for your drawing: Gravity Engine? Why not: Permanent Magnet Motor?
This design is on a horizontal plane on a vertical axis. The magnets are at 90 degrees to each other.
The Hamel design overcame the sticky point by adding in a horizontal axis that rotates on a center point which enabled a precessional wobble. The offset in your design was accomplished in the Hamel design by the inner ring entering and leaving the horizontal plane in a sine wave fashion during rotation.
One of the David Hamel devices shot up into the skies never to be seen again.
The next step after turning a mechanical output is to turn the fields and not bog the operation with frictional losses.
This is where the real promise is. Your device is well named.
The virtual side of the device should spin at an astronimical rate compared to a metal axle.
Well Gyula,
I am working on Perpetual Motion Machine and Gravity wheel concepts for many many years, in fact since my university days in UK. I must have made hundreds of drawings of different concepts on and off during these years.
In the end, I came to think that gravity alone won't make a wheel turn continuously, because I came to think that gravity force acts only vertically to the earth surface and only one direction, i.e downward.
I came to think that in order to make a wheel turn on a horizontal axle, we need at least forces acting in two directions: vertically and horizontally.
I tried to incorporate other type of forces with gravity in my new designs, like springs, elastiic bands, and magnets.
About six months ago, I came up with a new design that I thought looks good. I posted it on Besslerwheel .com in last december for the first time. It got mixed views.
Just to make this design, which I have named Universal Gravity Wheel, better I added the concept of using magnet in the design to add horizontal force to the wheel in the design.
I was overwhelmed by my partial test of my UGW device. It looked very good to me.
I posted on Besslerwheel.com.
You can view it there if you want to.
I was politely told that since my device uses magnets, I was on the wrong forum and that I should try OverUnity.com. Since then,I have improved on my UGW and now, I have named it Automatic Gravity Engine.
But what's in a name? The device that counts. Doesn't it?
Raj
Quote from: gyulasun on June 07, 2010, 08:57:14 AM
Hi Raj,
rgds, Gyula
The bigger the inside wheel the more "field tear time" you will have to overcome. The small wheel assures mutual field contact and quick field tearing action to get it out of the way and into the next cycle. But the actual final center wheel diameter may require fine tuning so that inside wheel is better to have adjustable magnets and adjustable center axle positioning, otherwise you may run into a checkmate condition from the start.
I love these ideas. They are so relaxing to the mind compared to our other works.
Raj Balkee
At first glance I could see what you are trying to do. But as you have it, it will not work for it will skip and find an equilibrium. I am highly experienced at this approach.
The first major change is you have to have each wheel geared and your spacing has to work with the gear ratio of the wheels. also you will have to have a top wheel added to keep it from jumping due to the magnetic fields.
I did a quick drawing of one of mine but took out what else I was doing. If you add your idea to mine. Between the two of us we might have a running magnet wheel. But will it be real strong? I doubt it, but it might be strong enough.
Alan Bauldree
Quote from: AB Hammer on June 07, 2010, 12:45:53 PM
Hi Alan,
I also think it can skip, mainly when you wish to use its torque for something useful but I do not think this is a reason for finding equlibrium: in fact all the sticky points in Raj's setup are overridden by neighbouring attract and repel forces so no equlibrium can happen. Of course the torque may be small but it should be steady when a small and stabile load is applied.
With your gear idea the skip can surely be eliminated (but with a decent flywheel it can also be kept at a minimum), however the gear system will surely consume some part of the useful torque just by its normal friction.
And with gear, why equlibrium could not happen?
Respectfully, Gyula
Quote from: gyulasun on June 07, 2010, 01:28:42 PM
Hi Alan,
Respectfully, Gyula
LOL Gyula
There is no guaranties, for if so, I would have already had a runner from this approach. I just never added magnets to it. So if it is going to be tried lets try to work out the bugs first. Then we can try it.
Raj Balkee
What do you think? by the way I like the last name for Balkee, it is allot like mine Bauldree. ;)
im not sure about this, but you never know.
Quote from: gauschor on June 07, 2010, 05:36:14 AM
I've got a couple hundred Neo magnets and mess with them a lot but no diamagnetic ones. I still think he's on to something and it appears he already has somewhat a proof of concept. I'll be following this with great interest as I've always felt there is a way to do something along these lines.
i think this guy was using the same principle... his method is a bit different though. :)
http://www.youtube.com/watch?v=9GlhV0-vHuc (http://www.youtube.com/watch?v=9GlhV0-vHuc)
Quote from: e2matrix on June 07, 2010, 03:01:31 PM
Hi e2matrix
IF you happen to have 16 sphere magnets, you may try a test with them too, the principle would not change, maybe you would get less torque vs the cylinder magnets, I think. Of course this just a suggestion. Fixing sphere magnets with the correct polarity orientations is not the best passtime...
rgds, Gyula
Raj Balkee
Alan Bauldree
Excellent drawing by AB and concept by Raj. I agree with you on needing gears and a tension wheel. Compare your drawing to the inner workings of a harmonic drive system. The tension wheel is done away with and replaced with an elliptical plug with outer bearings. There is also no backlash.
Here's a demo video of the harmonic drives,
http://www.harmonicdrive.de/german/funktionsprinzip/funktionsprinzip-film.html and a wiki link for additional information,
http://en.wikipedia.org/wiki/Harmonic_driveI believe your drawing is a better option for the "automatic gravity engine" than the harmonic drives, but I'm posting this to spur some thought around this principal. Maybe some aspects of the harmonic drive system can be incorporated into a working system based around your drawing and the concept of Raj. Excellent thread.
GB
Hello Alan,
Working together with you or anybody else, on a project of mutual interest, will be more than a pleasure.
No man is an island. More hands make a load ( mental and physical) lighter.
It is just finding a modality for working together.
Do you have a proposition as to how we can work together.
Our endeavour would be to try to make, possible, a working device .
Regards.
Raj
I would like to make some precision on my AGE concept.
There will be no skipping for the following reasons:
1. The weight of the larger wheel, which is very important for providing necessary torque to the small wheel, will be pressing continuously at the contact point on the rim of the smaller wheel.
2. Magnetic engaging actions will be continuous between the two wheels.
3. The smaller wheel will have fins (like in bobbins) to prevent larger wheel from slipping sideways from the smaller wheel. (see AGE drawing below)
Does my precision make sense?
Raj
My Atomatic Gravity Engine is UK patent pending...
Greetings from Mauritius to all forum members and guests.
I would dearly like to hear further of what you make of my AGE Concept.
I shall be delighted to work with anyone, as equal partners, if he thinks that there is something positive in my AGE concept.
Is it because I have mentioned that my AGE concept is patent pending that all of you, have nothing to add as reply to my post.
Patent application is only a way for claiming origin of concept. Partnership can then be made with anyone at anytime.
Please let me know if you see any merit in my AGE Concept.
Thank you all.
Raj Balkee
Huge forum full of ideas and so much to read. I think that is mostly why lack of replies here. I'm still following this but have little ability to build such a device and not much else I can think to say except it is always the actual build that will determine it's real world usefulness.
Hello everybody,
I feel very sad not being in a position to attempt a build of my AGE device, as I have explained earlier.
I will have to wait till Jan/Feb, next year to be able to attempt a build during my visit to UK where I know I shall have all the facilities needed to test my concept.
In the meantime, I am wondering if any of you will help me by attempting a build.
Maybe Alan, Gyala or Ematrix?
My offer for patnership is 100 % genuine.
Bye for now.
Raj
