My s1r9a9m9 replication!
Started by Super God, January 23, 2008, 07:26:21 PM
capacitor70
Quote from: resonanceman on June 08, 2008, 11:08:23 AM
Once  the  high  voltage  jumps the   gap in the spark plug  it   creates  a  plasma " channel " that is  relativly  low resistance .........  the much  lower voltage  can   follow this   path as long as the high  voltage maintains  the  channel
The high  voltage is in effect the switch  for  the lower  voltage .
It is the lower  voltage  ( high current )   that   flashes  the water  into  steam .
gary
Thank very you. for giveing this very important information. Soon I will make circuit for this effect.
gotoluc
Quote from: capacitor70 on June 08, 2008, 09:28:54 AM
Successful plasma water explosion test at 600 to 1000V DC, Capacitor Bank Discharge
Currently I am using voltage multiplier for this test
Trials with mosquito killer plasma pending. If any one have mosquito killer bat use this cicruit and tell me results, It is possible to
explode water with this bat. I tried this at friends home dropped some water on bat good explosion observed.
What is on the top of blast ? Shock wave  ??? every blast have that flying thing on top
Some Pics
Hi capacitor70,
great work ;D can you please share your exact componets you used and how you connected it and what did you use to get your 600 to 1000V DC.  I would like to replicate this a.s.a.p.
What is on the top of blast ?  Yes, that is the good part ;D I'll explain to you later, once I have it replicated.
Thanks for posting.
Luc
capacitor70
Circuit for water explosion.
Transformer is used for controlling voltage and isolation purpose. It also prevent mains trip
IT is must to use transformer
First transformer is having various tappings from 1.2v to 12V. By adjesting this I can control the output of second transformer
this way both control of voltage and isolation is possible
Do not connect it directly. First charge the capacitor to 600 or 1000V. Then sudden dischrge in water use switch
Take care high voltages
resonanceman
Some Pics
Capacitor
Looks very powerful
I am  guessing that   the   thing above the main  blast  is   something like  a  bubble  of plasma .......   If it is ......it would  be  great for  igniting   HHO   if the  direct  injection  doesn't  give  enough  power.
gary
gotoluc
Quote from: capacitor70 on June 08, 2008, 01:25:47 PM
Thank you capacitor70 for sharing your circuit. I have 3 more questions.
1. I have 4 microwave 1mf 2,000 volt capacitors. Could I not use them in parallel with 2 of the hight voltage diodes from the microwaves to do the same as your schematic or is there a reason to use so many capacitors and must they need to be polarized?
2. did you measure the amps (or better watts) consumed at the 220v input to do one explosion?
3. how much water is on the sparkplug before explosion?
Thanks for your time.
Luc
