Mars color
Started by raburgeson, May 22, 2006, 06:55:24 PM
0 Members and 250 Guests are viewing this topic.
raburgeson
Look again a the area 5 and 1/2 teeth from the left and 1/4 the way up from the bottom. That skeleton has an obvious airbrush beside it. I don't know what process they used to airbrush, but they missed the skeleton. The airbrush is present and large enough to cover but it hit immediately to the right of the artifact. They may have tried to use a program to do the airbrushing. Also I found a pile of bones at the bottom of a rock that is probably the leg bones for one of these to skeletons. You may notice white spots in the instant black shadows they airbrushed around the bottoms of the rocks here and there. What I'm trying to get across is they are up there. They are not just hiding stuff with airbrushes, they are moving artifacts, they are maintaining the landers. They are on Mars right now and they have been there for decades. Who are they, the same people that have you by the nads, the rich owners of the giant international companies and control the technology they refuse you. Look to the controlling interests of Lockheed Martin and companies like it that claim the be doing reverse engineering by way of disinforming leaks from exemployees.
You are under government control on every experiment you do. The rich control the government. It's illegal to work in certain frequencies, you are limited by the capabilities of your components, information is removed from sources you might find. remember the US government stated they intend to conquer the whole electro-magnetic spectrum? You can't experiment in petrahertz but they do, the components you are able to buy aren't capable. You know full well it you experiment in the wrong range the FCC or some other alphabet organization will come and bust you. Are you doing anything with the light frequency band? There used to be on the net a site that showed using a drill to twist wire  and building coils for scalar devices. That site lasted for days and it will never be seen again. I saved it. If I come across it I will post it, it's something they definitely do not want you to see. Your componets are also limited by their voltage and amperage carrying capabilities. Last but not least you are controlled by the cost of energy. The governments and many companies do not share these limits.
If you want to start a real fight try to get what we wanted, a direct line from a 25,000 volt powerline, try to get one of those.
raburgeson
http://www.stevesforums.com/forums/view_topic.php?id=47186&forum_id=72
The timer on editing is a pain in the butt, This is a continuation from above. As you can see the U2 carried a 4 gig camera. Why would they send less to mars? Why is this picture poorer quality than a picture you can take with your camera right now at home? Each section of the original picture had to be gigs in size when it was originally sent to were they send them to before they get filtered down to NASA. That's why it looks grainy, you are looking at a bunch of thumbs. You are all familiar with what thumbnails look like. look at the picture again, it's really had it's resolution cut down. By guesstimate I would say you could zoom in an additional 6 times on the original. How much proof do you need that they are hiding the truth about what's going on in space? They are outright lying to the people.
raburgeson
Incase you think I monkeyed with the picture befor the post I found a link to it straight from NASA.
http://sse.jpl.nasa.gov/multimedia/gallery/mars_rover_panorama_half-size.jpg
This is half size of mine, remember to click the cursor on the picture and click the + on the magnifying glass before right clicking and saving image as. This way you get it the full half size, your browser does that. When at full size the skeleton is viewable directly off their sight, 5 and 1/2 teeth over and 1/4 the way up from the bottom. The legs are on this one, the airbrush skullduggery is clearly visible by using equalize and zoom in. These are not rocks. They have been lying to us. I for one want the truth.
TheOne
I cannot find it, can you tell us what is the pixel coordinate? :)
raburgeson
OK, this is going to be a long one. I use paint shop pro to get the coordinates. You must not be using Photoshop, let me say first off, not all image programs are equal. If you can't see these things see a friend with a larger monitor that has Photoshop. There was a fairly large difference between the 2 programs that I was just using.
Coordinates:
Skeleton 4652,2828  Skeleton 3802,2504  Engine with bent pipe sticking out the front 2700,2248
Unknown Item 2636,3528  Pipe sticking out of the ground actually enhanced by airbrusher 6146,1144
Object with square hole 11763,1915  Dumbbell thing with extra knob 11757,2168
Item that appears several times 12102,2565  Pipe pile 17854,2087
Couple of large pipes airbrushed but shape unchanged 7462,1052
Pile of cement blocks cut up by airbrush 14281,2540  Airbrushed 60s style pop bottle 16558,2329
another item to many times 16225,2348  One of 100 stray discarded cement blocks 22041,3639
Very interesting (think it's bone) show you another one 3805,3353 - - 13251,2703
bottle with blue cap they didn't completely brush out 3598,2222
I didn't find the pop can that pass which we identified by not only the shape but the flaring stripe on the side, an older coca-cola can you may not be able to remember. My eyes are crossed and tired now so, I'm quiting for the day.
