Mars color
Started by raburgeson, May 22, 2006, 06:55:24 PM
Cap-Z-ro
The key to all tyranny is to keep everybody thinking they are contributing to a common good...while they are doing just the opposite.
This is easily done by compartmentalization as said above...all involved have no idea what they are a contributer to.
A look a ancient artifacts is all one needs to determine off planet visitation.
There is something to be said for childhood vaccinations destroying most people's ability to put information together and to detect patterns which enables one to see a things from a broader perspective.
And to those effected, life is but a series of unrelated events, to be reacted to with the appropriate emotion, and then moving on with day to day routines.
Regards...
raburgeson
http://www.ufos-aliens.co.uk/cosmicphotos.html
Here, history is important, this particular bit is moon history, but, still important. I don't know the name of the astronaut or which Apollo mission, However, it's findable. The thing is a colonized mars is much more important. The technology to go to the moon is far less than the technology to travel steady to a farther destination, terra form, and hide all that activity. They were doing this in 1960, they have even better Technology than that now, the people payed for every last bit and they have been denied access to it. So, catch up on history. We have to beat this information out of them and some of them will not survive the beating. They killed a US president to keep this secret. Stay on Mars colonization, it happened, there are Earthlings living on Mars and I have no indication of aliens living on Earth. Beware the lying thieves, they have plans and options to create a false flag alien attack or produce an alien. According to the amount of research money they have spent they should have been capable of presenting us with a human hybred in 1955. They got used to lying to us and we believe them, now put the technology on the table we won't believe you no matter what you say. That's how much credibility they have left.
raburgeson
I'm going to get you ready for it because it's going to happen. The Chinese are aware of the situation now. They need both elbow room and farm land. No matter what deal the NWO thinks they made the Chinese are going the throw the proceeds back in their faces and get what they need. 2 to 3 months from now tops. The NWO never got the great kings in place China never marched East, the prophecy the NWO was pushing to happen didn't. You can quit feeling the end times gloom. The Chinese are looking West now and they are going to do what they have to do, what ever it takes.
Groundloop
@Koen1,
I would like to address some of you comments about Mars and color. In the beginning of the NASA Mars rovers mission  NASA had computed that the solar panels on the rovers would be gradually covered with dust and loose power. Further,  NASA always have claimed that Mars was a "bone dry" and dusty RED planet. Then the European came along and started to send back pictures and radar data from Mars. (Mars Express satellite.) More on this later.
Now take the camera on the rovers. The panoramic camera consists of a (Pancam uses 1024?2048 pixel Mitel CCD array 1024x1024 is used for imaging.) detector where each light sensitive pixel is much bigger than on an average Earth camera so that the camera can be light sensitive. In from of the camera is a rotor with many color (Each filter wheel has eight positions, allowing multi spectral sky imaging and surface mineralogical studies in the 400-1100 nm wavelength region. The left wheel contains one clear empty position.) filters, including several infrared filter. But three of them is Red, Blue and Green. The Red, Blue and Green filter is 100% the same as if you buy filters here on Earth for black/white photographing to color images. (You take three pictures and combine them to color later on.) So if you use those three filters you get a reasonable good color image.
But that is not the whole story. The rovers is on Mars and that is an awfully long way from here. The rovers has UHF and  VHF transmitters and you can not put in very strong transmitters because the rovers run on solar energy. To save energy the transmitters has to be used as little as possible. So to be able to send the images (and other data) to Earth they use image compression. (Image compression using a JPL-developed wavelet compression algorithm called ICER.) The modes for the compression is commanded from Earth. The compression ranges from almost no loss to very lossy compression. But still the images (after decompression and computing to color) looks pretty good. The color information is OK and if they use the infrared filters the science data is very good.
Now to the "Raw" data that we see on the Internet. The images is compressed once more to save space on the NASA servers, and this time with JPG compression. NOW the images looks very bad. There is so much compression artifacts that is is almost impossible to resize the images.
Now back to the "bone dry" and dusty RED planet. The rovers solar panels has NOT accumulated the amount of dust over time as predicted by NASA. So what did the do? NASA "invented" an explanation that the solar panels cleaned them self each night! Maybe by wind. No other explanation was put forth. I think is more "down to earth" to say that the amount of dust in the atmosphere is NOT as high as NASA claimed.
So now we had the very RED images of the ground and sky. Then the Mars Express satellite toke this (attached 1 craterice.gif) image and released it on the net. This "forced" NASA to "relax" a bit on the redness and they released this (attached 2 marsbluesky.jpg) image. Now the sky on Mars is suddenly blue. Why did NASA do this? They did it because of the following reason. The only way the ice in the crater can be blue is if the atmosphere on Mars is different from CO2. The ONLY gas that can color the ice blue is Oxygen. We still has the same lightning source both on Mars and Earth, the Sun. So now we have a planet that has a blue sky. Is there water on Mars? Radar data from Mars Express says yes. There is a lot of water on Mars under the ground and also in craters. The North and South poles also have a lot of ice. It seems that the planet Mars is NOT so "bone dry" and dusty after all.
Now I like to address the possibility of NASA using paintbrush (or computer aided equivalences) on images. Can I find any examples of images that are manipulated? Yes in fact I can. In this image (attached 3 marsembossedcolorskyline.jpg) I can clearly see that NASA (or ?) has removed the sky and replaced it with a uniform ugly pink. You can tell because the noise is missing in the sky part of the image. Why they do this is a mystery to me.
So, now we know. The sky on Mars is blue. There is water (ice) on Mars. There is wind on Mars. There is probably also vegetation on Mars. The only way ice can be blue in a photograph is by sun light filtering through oxygen atoms in the atmosphere. Can there be higher lifeforms on Mars?
Groundloop.
Koen1
Thanks Groundloop!
That is a very nice reply.
Great to have your input. :)
