Stirling Engine
Started by mindsweeper, August 09, 2007, 09:34:41 AM
resonanceman
I  forgot a little  detail  about the   compressor  disk
It turns out that   on a disk  like this   at the  place where the  air  exits   you have a choice to make .
The normal way  to  do it is to have the  compressed air just flow  straight  out .
If  you   design  the  vanes on the  disk  so that they curve  you can  have the  air exit almost   parallel  to  the  direction of  motion .......... in other words  you can get some free thrust   from  the  air .
gary
joegatt
Yes Gary, the heat reservoir between the hot side and the cold side is important for the efficiency of a stirling. It's called a re-generator. In the case of a gamma stirling, like the one in my picture, this function is partly fullfilled by the temperature gradient along the walls of the displacer cylinder, and those of the displacer itself.
By the way, if you want to recover web pages from a discontinued website, you may find them on www.webarchive.org , if you're lucky.  But I wouldn't worry too much about it. From what you said about that O.U. design, it all sounds pretty complicated. The simplest designs are usually the best.
For example, I once toyed with the idea of using a linear motor to drive the displacer thereby eliminating leaky seals. However it turns out that, for a small machine at least, the whole setup becomes very inefficient!
Anyway, I'll try to stay focused on my rotary for now, and I promise to post pics and movies if I manage to get it running.
Joseph
resonanceman
Quote from: joegatt on July 12, 2008, 03:02:45 AM
Joseph
Joseph
The  compressor disk  would  take some doing    .......The rest of the motor is pretty simple .
I am looking forward  to  seeing  your progress.
gary
I've built a few Stirlings, and I have a rotary-displacer LTD unit under construction right now. The seals are the big problem for me.
Here is a video of a small  coffee-cup Stirling that I built a couple of years ago. The power cylinder is graphite, the power piston is aluminum, the displacer is pink construction foam, the working gas is helium in the video, but air is fine too, just less efficient. It will do 600 RPM on a good day, and usually runs for 60-65 minutes on the heat from a cup of hot coffee.
http://www.mediafire.com/?2bmktk95xcx
I'll try to post some pictures of the rotary construction project. I'd like to see other's designs for this too.
Thanks--
Tinsel
resonanceman
Quote from: TinselKoala on July 12, 2008, 11:58:50 AM
Thanks--
Tinsel
Tinsel
That  is a really cool  sterling
Very well built
I had hopes of   using    the heat  from  the  water / plasma     to  drive a sterling .
Judging  by   another thread  ........if  it  can be called  cold fog   there might  not be enough  heat there .
Is there enough heat  released to  capture  with an engine ?
If not ...... I have seen  videos  of  engines   kicking over with water alone .     What would be  driving them ? just  the shock wave?
gary
