Roll on the 20th June
LarryC
Quote from: ramset on July 12, 2008, 05:36:20 PM
Larry you have a nice KISS design rotating the arm 90 degrees can get the weight even closer to center   Chet PS Archer can you post your mag array config for larry?
Thanks, Chet, but I've seen his mag array many times in his video. That is what my little blue dots represents, a side view of his mag array. Archer has the only design that I've seen that can move large masses at high speed.
Regards, Larry
The Eskimo Quinn
Shak made a drawing, he sent to me, dont know if he posted it, i only read the last page when i log on.
basicaly if you look at the Standard original wheel the outer magnetic arcs run around it to stop the rod falling back after firing, but if they were the shape of the roller as in shaks drawing with your blade desgin they would fire in and stay there number one.
Number two if you had both together the firing from the outer may break your track wall. only thing is the rod would need to have the mags latteral for the track under. talk to shak and everyone else and see what you come up with.
I have gone too far on the wheel to change the design. But at the end of the day, it is the technology that will matter, i am sure there will be a heap of designs around these new principals. And I highly doubt ten years from now mine will be the best. simply the original basis for them.
My PROOF THAT DEMOCRACY IS DEAD AND THAT WE MUST ATTACK AND KILL THE NAZIS IS RIGHT IN FRONT OF YOU, THE U.S, aUSTRALIAN AND BRITSIH GOVERNMENTS ARE THE OPPOSITION PARTIES TO THE ORIGINAL INVADING GOVERNMENTS, DEMOCRACY DIDN'T WORK, BOTH MAINSTREAM PARTIES ARE NAZIS, DEATH TO THE NAZIS, DEATH TO ALL SYMPATHIZERS AND SUPPORTERS http://www.youtube.com/watch?v=39c-kpgDY58&feature=related
ramset
Thanks Grandma
@exxco: lol. So, every time I use my big old Crescent wrench, I am taking advantage of that "banked energy", and when I bequeath the wrench to my great-grandson, he's still able to draw on it. Talk about Infinite Energy!
Just kidding, I think you are both arguing around the same point using different terminology. I'll just stand here and pass the number around...
I just wanted to distract youse guys and get back to Archer, that's all.
So, where's that working wheel that worked, then stopped working, Archer? I can't find the video of it for some reason.
exxcomm0n
@ all
Here's a graphic of the dual gate that still needs to be tested.
Will being uneven be enough?
Only testing will tell!
:D
When I stop learning, plant me.
I'm already of less use than a tree.
