Thane Heins Perepiteia.
CRANKYpants
Quote from: Zayith on July 13, 2008, 06:40:21 PM
Hello Thane
Congratulations for your last impressive achievements.
Please consider improving the system by adding magnets wheels and coils as explained in Stage B and C in the attached diagram. I guess it maybe can increase the performance several times.
Cheers,
Zayith
N.B: Magnets wheels must be identical in dimensions, magnets number, and magnets positions.
THANKS FOR THIS ZAYITH!
ACTUALLY I HAVE DONE WHAT YOU SUGGESTED BUT I PLACED THE COIL BESIDE THE MOTOR AND HAD ONE ROTOR ON EACH SIDE OF THE MOTOR.
THE SYSTEM ACCELERATED AND PROVIDED POWER BUT MY CRITICS TOLD ME THAT THE COIL'S MAGNETIC FIELD WAS INTERFERING WITH THE MOTOR'S STATOR FIELD AND IT DIDN'T WORK - EVEN THOUGH IT WAS ACTUALLY WORKING?
MY PERSONAL FAVORITE COIL DESIGN IS A "U" SHAPED COIL WHICH CONTACTS BOTH SIDES OF THE ROTOR MAGNET AT THE SAME TIME.
UNFORTUNATELY OUR NEW COIL DESIGN SHOWN HERE: http://www.youtube.com/watch?v=FmFbINO0dCUIS NOW SOMEWHAT COMPLICATED TO MAKE BY HAND - SO IT IS SLOWING US DOWN SOMEWHAT.
Thane
CRANKYpants
CHECK PLEASE!!!
HERE IS THE DATA FOR OUR LATEST BI-TOROID PROTOTYPE
(It is the same design as previously employed but with a more efficient primary to secondary delivery.)
INPUT
10.34 volts
0.74 amps
Power Factor = 0.13
Power = 0.995 watts
OUTPUT ACROSS 100 ohm LOAD
14.14 volts
Power = 2.0 watts
Efficiency = 200.9%
I will be posting some photos once I return from Toronto.
Cheers
Thane
LarryC
Quote from: CRANKYpants on July 12, 2008, 09:16:12 PM
DEAR I_RONVELATION,
THE POWERS THAT BE ARE NOT IN CHARGE HERE...
THEY HAVE BEEN DUPED.
UNIVERSAL INTELLIGENCE IS IN CHARGE - PERIOD.
EVERYTHING IS A VARIATION OF GOD (OR GOOD) - EVEN THE SO CALLED NEGATIVE "POWERS THAT BE".
THE "OUTWARD" EXPRESSION OF NEGATIVITY FROM THE POWERS THAT BE SIMPLY EXISTS  TO SHOW US OUR OWN "INNER" NEGATIVITY. WHEN WE ALL COLLECTIVELY ELIMINATE OUR OWN NEGATIVE TENDENCIES - INCLUDING BELIEVING THAT SUCH AND SUCH IS "NEGATIVE" THE POWERS THAT BE WILL DISAPPEAR. IT IS UP TO EACH OF UN ON AN INDIVIDUAL LEVEL. FOR EXAMPLE, IF WE WANT TO STOP GLOBAL TERRORISM WE SHOULD FIRST STOP TERRORISM IN OUR OWN MINDS AND HOMES.
ONCE I GET THE TRANSFORMER WORKING TO MY SATISFACTION - BEYOND ANY SHADOW OF A DOUBT  - I WILL COVER IT WITH BAR CODES THAT I AM NOW COLLECTING AND I WILL SHOW YOU THAT - THE DARKNESS OF NARROW SELF SERVING HUMAN IGNORANCE IS NO MATCH FOR THE LIGHT OF INFINITE SEVICE TO ALL..
Sorry, I did not realize your full understanding. Let me know if I can help brother.
Regards, Larry
LarryC
Quote from: CRANKYpants on July 13, 2008, 07:33:55 PM
CHECK PLEASE!!!
INPUT
10.34 volts
0.74 amps
Power Factor = 0.13
Power = 0.995 watts
14.14 volts
Power = 2.0 watts
Efficiency = 200.9%
Cheers
Thane
Now that is out fricking standing! Great job Thane.
Regards, Larry
CRANKYpants
Quote from: LarryC on July 13, 2008, 07:46:05 PM
Regards, Larry
I CAN TALK THE TALK LARRY - STILL LEARNING TO WALK THE WALK THOUGH.
I AM IN THE PROCESS OF UPLOADING OUR 180% EFFICIENT BI-TOROID TRANSFORMER.
COMMENTS WELCOME.
NEW BI-TOROID TRANSFORMER VIDEO
http://www.youtube.com/watch?v=Cka7qb0zoc8
CHEERS
Thane
