Feynman makes a Bedini Motor
Started by Feynman, April 18, 2008, 12:41:22 AM
WilbyInebriated
Quote from: willitwork on July 19, 2008, 12:02:55 AM
So you have never built one.
hehe
have you even read this thread?
try page one, where i spent time correcting PMM. another talking head who thinks any motor that uses a pulsed electromagnet is a "bedini type motor"  ::)
i followed the directions and didn't "make up" some circuit and call it "bedini type"  :o
WilbyInebriated
Quote from: willitwork on July 18, 2008, 11:56:14 PM
And what precisely was your build and testing methodology?
How does your system work?
What are your numbers?
How did you get your system into resonance?
Did you take the charged battery of your resonant Bedini and disconnect it, then flatten it, then recharge it?
I didn't need to because I know a pulse charge when I see one.
ahhh lets see, i actually built one according to specs, unlike you, which makes my methodology superior.
works by magic  :o
42
the usual way
yes
i needed to because thats science, nothing personal.
willitwork
I have read the thread, I remember smirking at the guy PMM humiliated - now I realise who it was.
You state that you recovered a cell phone battery. Those are not lead acid. Magnerazz says that
"That other battery chemistries don't work illustrates the quirky nature of the physics involved."
In other words Magnerazz says that only lead acid batteries work in this type of system. The link to his comment follows:
http://www.overunity.com/index.php/topic,4515.msg113434.html#msg113434
(sorry I am not linking correctly)
Now Bedini did some work with other types but he referenced the negative resister effect in Lead Acid for the most part.
If you are recovering non lead acid batteries you are confirming my position perfectly.
Which of the Bedini circuits did you use?
Can you flatten the target battery and recharge it?
Reading a higher voltage on a battery under charge proves nothing.
WilbyInebriated
Quote from: willitwork on July 19, 2008, 12:34:24 AM
i can charge all sorts of batteries, LAB's perform best
i have not confirmed your position at all... especially with an "anectdotal account" according to the talking head PMM. you say it confirms your position and he says its inadmissible... how is that possible?
yes i felt so humiliated by the guy who hasn't built one talking about being scientific... ::) hrmmm i'm getting that same "feeling" again.
the sg circuit
yes, and run a load off of it. most any battery type.
OBVIOUSLY
willitwork
Ok, now we are getting somewhere. This is right back to my initial post.
Completely flatten the target - (charging) battery - (Battery-A)
Completely charge the source battery (Battery-B).
Start the Bedini.
Charge the target battery (Battery-A) up without touching the source battery  (Battery-B). Don't put any external charge in either battery ever.
If the Bedini is working as you suggest you have charged a battery  (Battery-A) with leading pulse, aetheric etc energy. Congratulations.
Now Put the charged battery (Battery-A) in the source position.
Flatten the battery that was the source battery  (Battery-B).
Charge it with the Bedini.
My original post did not call for the full discharge of the target battery (Battery-A) , if you wish the light bulb approach mentioned earlier will work.
To complete this you will need to demonstrate that you can keep at least one battery fully charged no matter how many times you swap them.
I am letting you off easy because most Bedini evangelists would seem to claim that they can keep both batteries fully charged.
If the Bedini is just a pulse charger you will not be able to fully charge the target battery and after you swap the two out, the system will run down to a miserable grinding halt.
PS, I worked with early Lead Acid batteries in two way systems in the seventies. Back then we used pulse systems to rejuvenate old lead acid and early dry rechargeables regularly.
NB A battery may come up to voltage but that does not mean it is fully charged or functioning to capacity. Earlier suggestions that a Bedini system actually destroy batteries may be completely correct. Pulse rejuvanation will occaisionally give a battery a new lease of life.
Another Prediction: Assuming both batteries are identical you will never be able to fully charge  (Battery-A) from  (Battery-B) in a Bedini circuit.
