Mysterious Resonant Circuit
Started by EMdevices, July 24, 2008, 10:04:51 PM
spinner
Hi!
Sorry to say, but this simple circuit is not, and will never be an  "OU" configuration.... A transistor and a few components - I think this is one of the most researched circuits in past century, wouldn't you think?
Like some people said before, the faulty measurement procedure and consequent errors are to blaim...
Seeing all those different "OU el.circuits" all around the web - not even a single el. component / circuit (being that passive or active) has ever been scientifically recognised as an option to invalidate CoE...
The man-made electronic components are by it's origin and definition just a conservative devices. The passive ones, like C and L are the ones which can sparckle some ideas.... Let's say, in a resonant condition. Which would be exactly unity under ideal conditions....
Yet you all know that there's actually no ideal capacitance or inductance... There's always a resistive component, which is an equivalent for a friction in mechanical devices. Having an oscillating circuit, there are radiated losses, too.
The main goal for engineers wrt. electronic devices is to come as close to an unity as possible (in energy terms). But semiconductors are 'f...ed up when it comes to energy efficiency'.
Unless someone defines where the additional energy is comming from (sucking energy from e.g. the "surrounding heat, Aether, ZPE, Dark energy,...  "), there can be no valid claims about 'OU'.
"Ex nihilo nihil"
aleks
spinner, so what? The text like yours is a standard one, no need to reiterate it - I doubt guys over here are stupid not to understand that OU is impossible in conventional equations. But these schemes are real world - they are not equations. You are also missing the point that not all real world schemes make "sense" in equations rendering equations useless.
Do not pretend physics "knows it all" - it is still unable to unite quantum mechanics (electro-dynamics) and general relativity theory (i.e. electro-magnetism and gravity) - both are "sane", but somehow incompatible. There's a great abyss between both as far as I know.
I think "Mass" and "electricity" controlled together is what makes overunity possible - but they are exactly things NOT united in physics, so you can't tell for sure a'priori - there's no theory for that exist.
aleks
To tell what I've mentioned exactly: "standard model" (which is based on laws of conservation among other things) has no gravity in it, and has some deviations with real world data. You just can't be serious telling overunity does not exist in this universe, especially considering some people achieved it. Do not underestimate "filters of perception" in human brain. Many "unwanted" or "unimportant" things are usually left unexplored. Simply remember who you was at your younger ages: you "saw" basically nothing, because you had no idea about what you saw. In an older age you have a lot of ideas, and you "see" things, but unlike in a younger age, you are stopping new ideas from entering your brain. That's what "filter of perception" is. Your younger state is what brought you to where you are now.
aleks
EMdevices, please do not forget about Faraday cage test.
EMdevices
@ xee,   I used a 1/4 watt resistor because that's what I have.   I'll go buy some higher values ones.  Also,  I don't worry about the resitance GOING UP WITH TEMPETURE,  since that's not what happens in practice.  As the temperature heats up, the resistance goes down, not by much in this case.  For example lightbulbts can drop from 130 ohms to 30 ohms, I've measured it first hand.
@grumpy,  the battery does not heat up.  I understand those battery charts, its the mAh, a measure of energy, so if you drain more you depleate faster, that's all.  But you can draw two amps if you really wanted.
@aleks,  yes the voltage is more like 6.5, but I like to err on the side of caution.  I did some rough calculations of my margin of error and the COP can varry from 1.35 to about 1.20.
@willitwork,  yes I've been thinking and planning to do this ultimate test to prove OU without a shadow of doubt.  However, it's a bit trick, and the reason is that the oscillator and the output power depends on the load resistor.  I tried different resistors and I get different performance.    This is not uncommon, most stages in an electronic system need matching between stages.  So, I am researching and thinking how I can do this effectively.  OU engineering is not as easy as it looks.
EM
