Another YouTube Claim
Started by CLaNZeR, July 28, 2008, 03:04:28 PM
Yucca
Quote from: therealrasta on July 28, 2008, 05:18:13 PM
Oh shit.. I watched it again and just noticed the wire!!!!!!!!!!!!!!!!! How could I of missed this.. Ok.. gonna look around for some wire.. Maybe that will allow it to spin longer? Will let you know.
Good luck therealrasta! ;)
he uses very thin wire, looks like speaker coil wire or something like that, not suprised you missed it, when I first watched it I thought the top wire was just swirly scratches on the disc. The top wind is helix coming up of the disk into the air, the bottom wind I can't see, to me it looks like the wires go from the DMM leads and just go to two of the stator neos but I could be wrong on that? If it works, I suspect the top wire will be a closed loop.
TheOne
What have you done to make the rotor float over the magnet?
therealrasta
Could not find any 30 gauge steel wire.. So I bridged the mags with steel needles.. Maybe the same effect as steel wires?  Still does the same thing , rotates, oscialtes, then stops.
So if it is real.. Then maybe the wires coming from the lower mags connected to the meters are actually the true driving force? Would try and hook up my meter but like I said no steel wire.
Yucca
Quote from: therealrasta on July 28, 2008, 05:26:54 PM
You could try very thin copper wire, just get any multistrand copper cable, like 9v powerbrick lead cable and strip off insulation then you'll get many strands of thin copper wire. Then try and wind the top like lots of springs joining each neo. I don't have enough neos to try this.
P.S. I don't have a clue about the bottom wire config.
therealrasta
Quote from: TheOne on July 28, 2008, 05:26:32 PM
Simple..
1. 8 sets of 1 mag on the bottom of the lower wheel with 2 on top with north facing up around the inner groove of the cd.  I got the locations by splitting the disc like a pie with a square and marker to be exact..
2. 8 sets of 1 mag on the top of the upper wheel with 2 on the bottom with north facing down. I put them on the outside edge of the cd.. I got the locations by splitting the disc like a pie with a square and marker to be exact..
3.Did the same with as 1 and 2.. Just replace north with south.
4.Tried it with steel needles to bridge the upper disc mags.. Put the needles on the top of the upper disc..
Findings = Rotates, Oscilates, then stops.
