New accelerating gravity wheel ! Converted video from www.newenergymachine.com !
Started by hartiberlin, May 11, 2007, 12:49:03 AM
4Tesla
Is Knex a software simulator?
Edit: found it on google.. it is a construction set..
noonespecial
OK....its official. I'm a total idiot! I can't believe that I missed this part. Stay tuned...I think I have something that will get us closer!
LarryC
Quote from: noonespecial on July 28, 2008, 01:17:10 PM
Can you show a video of Knex working?
A video wouldn't help, to hard to move without falling over. So I took the start and end picture. The ruler is hard to see in the second picture, but the center pivot point moved from 5 1/2" to 7". Glad you asked though, it doesn't seem enough of a percentage move.
It seems like a lever of this kind would have to be on the fixed lower base and would be picked up as the arm hit 4:00 and released and spring back as the centrifugal force takes off with the weights.
Regards, Larry
noonespecial
This thought came to me while I was mowing the lawn and I went back and looked at the video again. I don't believe that he ever really said that the weights traveled back and forth like I originally envisioned. The video (which is really hard to see...I wish Bob would take mercy on us and throw us a few more hints :) ). Anyway, it would seem that this, while its still probably not exactly what he is doing, would take less effort to achieve. Let me know if you don't understand what I tried to show.
LarryC
Quote from: noonespecial on July 28, 2008, 08:32:26 PM
Forgot to mention your earlier comment about the arm not moving. Had seen it, but though it was due to the high speed of the arm, taking more time to sling the weight.
About your new design, easier but don't think it is what Bob's was doing. Look at the pic that I attached. At the bottom of the arm you can see the four springs being pressed down by the weights and the four rods pushed thru. At the top you can see the unpressed springs with the contact bar that the weight would hit. It appears that the weights are sliding on/between the wide flat steel bars on each side. The weight connecting bar must be behind the arm, offset to miss the center axle. Just hope we don't need the large shock and piping. I think the base has the actuator arm and cam, see the metal bars. Unless it junk, what purpose other than to assist?
Regards, Larry
