this pyramid should produce electricity. (thomas trawoger's pyramid explaned.)
Started by nitinnun, July 16, 2008, 04:57:47 AM
nightwynd
Thanks for the props there guys :)
Yeah, all I need to find is the copper now. Good call on copper flashing Jeanna - I'll look into that either this weekend, or early next week. Don't think I'll need a lot of it.
Ok, gotta fly now - I'll post again soon.
Nightwynd.
Need motivation? Read: http://www.lifeaftertheoilcrash.net/
Sincerely - nightwynd
nitinnun
i came up with another insight.
the earth is covered in neutrally charged magnetism. generated by the spinning of its core.
copper polarizes this neutral magnetism, into positive magnetism. (clockwise spin)
iron polarizes this neutral magnetism, into negative magnetism. (counter-clockwise spin)
in my glue cells, the glue/water/whatever, transfers the positive magnetism from the copper, to the negative magnetism in the steel.
in a pyramid, the positive magnetism in the copper peak, is transfered to the negative magnetism in the aluminum base, THROUGH THE AIR, by the current of the pyramids magnetic field. or something along those lines.
the strong current caused by the copper peak, and the strong magnetic potential stored in the copepr and aluminum, allow both of them to interact.
this thought isn't complete yet. but i feel that it leads to an important breakthrough, in how the pyramids energy functions.
at the least, it explains how my glue cells work.
nightwynd
Hey nitinnun,
Any thoughts on exactly how to construct/design the antennae inside? I'm wondering what kind of material and what arrangement would be best...the coil that I put in 3d there, or a frayed burst of wire? I'm still trying to source copper foil or flashing locally, and I'd like to get the antenna material at the same time If I can.
Nightwynd.
nitinnun
nightwynd
Quotemake the peak antennae be a flat, counter-clockwise spiral.
Would the base antenna then be a flat clockwise spiral?
What gauge of wire would you recommend?
What size of capacitor should I look for?
