My s1r9a9m9 replication!
Started by Super God, January 23, 2008, 07:26:21 PM
happyvalley808
@Cap70,
You said with the orginal diode circuit, the solder was melting during trials.......Do you think an increased number of diodes
lets say -24- 6A10 in series . Would the increased number of diodes reduce the waste heat ?
"HAIL CAPACITOR70"
Mahalo Nui Loa
HV
tiltfulll
Oh I see where you going! ;D
You trying to use a Bedini motor to keep the capacitor charged!
Right?
Sounds interesting!
Ricardoch
Hi all
Hail Cap70  ;D
I was rebuilding Capacitor coil circuit (after burning some inverters days ago) and testing each step before each other and found something, at least curious. (sorry no camera, but easy to test yourself)
I build HV Capacitor part and started playing some sparks with a 555 timer circuit posted some days ago, nothing spectatular but funny to play with sparks at different pulse speeds
Then I attached the toroidal coil and HV condensers, only the HV side of toroidal coil (The insulated wire) and sent a few pulses to see if coil and condensers keep the sparks going on, and the spaks went MUCH BRIGHTER  :o  than the usual direct plug conection to the car HV coil. nice!!!
Tried some water and seems a little more brighter sparks, althoug if too much water added and contact went closed with a water drop, there are no sparks at all, (first impression was I have already fused something again).
Cleaned the plug, repeated test, bright sparks again and tested LV side of toroidal coil, BE CAUTIOUS very High Volts on this side either, and what is more interesting...
Closing the LV toroid coil (magnet wire side) results in MUCH BRIGHTER sparks and more water reaction.
I have no opportunity to go further today, unforunately I can spent only short time from time to time to the project, but maybe there is a way to bypass or improve the LV requirement??
As I have not too many tools nor meters here, just a couple cheap MM, for some time I can only advance on the try-error-melt-something-get-some-spares-try-again-and-put-some-attention-next-time "scientific" metodology ;D
But maybe some of you can test it a little further and check some toroid coil configs to see if it's possible to improve spark without LV and the associated problems.
maybe it`s not woth the time, but I have the feeling that playing with coil and HV capacitors could provide interesting effects, I`ll try more test as soon as I can.
I used the initial toroid 32 - 12 ratio, hope this helps.
A last note, for me, making a cheap 555 pulse timer is a must, you can leave the whole thing sparking on it's own and play different test on the fly,  I will not have noticed the coil effect on a charge - spark by hand basis.
I`ll try to attach the Cap70 circuit as tested.
Best to all.
R
adamhy
Cap, how about this circuit?
capacitor70
Right?
No bedini motor.
Its like Tesla switch. (for information : somewhere I read that using tesla switch 4 batteries some one is running his car without charging
batteries) http://www.ctglabs.com/tesla1.htm
Increasing diode dosen't make any difference because plasma resistance is zero so no power loss in the plasma spark plug, all energy goes into the diodes and wires. That's why the charge of capacitor can be circulated without problem. take two capacitors, charge one capacitor, and charge second capacitor from charge of fist capacitor through spark plug acting as switch.
@adamhy
Similar to diode circuit.
@tiltfulll
Reply #609
During capacitor discharge transistor becomes on agin and acts as wire, no difference same as normal circuit. (for trials use SCR for simplicity)
