Tri-Gate Motor (TGM)
Started by 4Tesla, August 03, 2008, 05:08:36 AM
nightlife
Here is a design that I had drawn up some time ago. This is a three to one ratio and did not work do to the gate's attraction being stronger then the work being done but I am working on a updated version that I have not finished yet.
4Tesla
I still don't have my magnets yet.. but anyone that has magnets, this might be worth trying.. according to this Vizimag software by having longer magnets at the begining and exit of the tri-gate array.. you should have no or little wall.. check out the flux field lines in the attached graphics..
Jason
Magnerazz
I have found one of the most useful tools in vizimag is the force calculator. This translates the influence of the field on a ferromagnetic object into kinetic force expressed as x and y vectors. The vector sum  of these forces determine whether you have rotor motion in a favorable direction or not. The problem with any rotary model for a permanent magnet motor is that the vectors required to maintain motion are 180 degrees out of phase on the opposite sides of the rotor, so the fields if properly arranged on each side tend to cancel each other out and weaken the rotary motion. A magnetic motor is driven in exactly the same way as an electric motor, except that with the electric motor you can turn opposing fields on and off as needed.
Razz
4Tesla
Thanks Razz!
I have attached a couple more graphics.. this time with the gates spread out.
Jason
4Tesla
Quote from: 4Tesla on August 03, 2008, 10:21:56 PM
Thanks Razz!  Good prices!  I'm going to order the $15 set.
http://www.magnet4sale.com/home.php?cat=321
Forgot.. I want to let people know that this sites (magnet4sale.com) credit card process in only partially encrypted.. not good.. The good news is that you still can use PayPal which is safe.
Jason
