Selfrunning Waterpump-generator device runs 60 Watts lamp...
Started by hartiberlin, July 16, 2008, 03:09:31 PM
fritz
Quote from: aether22 on August 13, 2008, 07:21:03 AM
Hey, great to see you here!
I have a theory about how your setup works, I believe that flux is leaving the motor through the holes and being absorbed in the external circuitry inducing more energy than any normal estimate would guess. (I believe the flux is 'radiant', that it rides on aetheric shockwaves released by the rewound generator)
Is this in your opinion correct or possibly correct?
Is there ANY chance of getting info on your circuit?
Thank You.
BTW if you think my 'theory' sounds crazy, well so do I.
But it seems that that or something very much like it is possible based on my research.
note: sorry about the extra long sig, will prune it in a few days.
I?m not sure if your post complies with the 2nd line of your sig.
k4zep
Thank You.
Hi James,
I think it sounds crazy..... "I believe the flux is 'radiant', that it rides on aetheric shockwaves released by the rewound generator"
  Yep, Nuts.  Even you admit that!
Unless you can prove a RADIANT flux which by definition is something going out "radiant"....and you need something coming in to get more of something plus once it goes through the holes, it is outside the coils!  no coupling!, Unless you can prove the existence of an aetheric ( what the hell is Aetheric?" shockwave in this configuration...........Yep sounds crazy to me.
Please post a working circuit that will demonstrate radiant flux (and instrumentation to indicate it is "radiant") in a multilayer iron core generator and demonstrate an aetheric shockwave (camera) and show in operation!  We don't need theories, we need working devices!
Theories and words are cheap!
Ben
JDHardy54
Last night we all got together at my house.  We worked two hours and we eliminated the paddle wheel and the pump as being the problem.  We hooked up an electric motor to the generator shaft and ran several tests and found a few problems with the generator.  My partner is a Master Electrician and has a workshop at his house where he rebuilds generators and motors.  I will be going over this weekend to work with him.  We should be all set after this weekend.
Thanks everyone for your comments and suggestions. Keep all the ideas coming - it's all helpful and good stuff.  I'll get back to all of you but right now I have to go back to my day job.
James
khabe
Is it possible to prepeare the falsity by a Master Electrician?
Never!
khabe
fritz
Quote from: khabe on August 13, 2008, 06:12:16 PM
Never!
khabe
prepeare for Trolltime !!!!
Better Master Electrician as Master of nothing.
