New accelerating gravity wheel ! Converted video from www.newenergymachine.com !
Started by hartiberlin, May 11, 2007, 12:49:03 AM
4Tesla
@noonespecial
Thanks.. I'll take a look!
@LarryC
Wow.. looking good!
Jason
noonespecial
Hi Larry,
I think I'll whip up your design in Phun and see what happens. How much weight were you using again? And how are you activating the levers?
Thanks,
Charlie
LarryC
Quote from: noonespecial on August 15, 2008, 10:25:04 PM
Hi Charlie,
The weights are 7 lbs in each box, appreciate your proposed Phun efforts, but I don't think you can simulate without considering the stored centrifugal force in the bungee's. I don't know what this stored force will be until I can test and I'm sure it will vary with the rpm's.
The levers will be activated by a fixed stop at 4:00, which will hit the center pivot of the lever and the pivot will slide along the stop until the two weight boxes reach 1" pass the mid point and then drop off. The main timing problem will be releasing the stored centrifugal force at exactly the right time to support the starting movement of the levers.
Hopefully, this is close to what Bob was doing, but since he remains silent, who knows?
Regards, Larry
noonespecial
LarryC
Quote from: noonespecial on August 21, 2008, 07:32:54 PM
Hi Larry,
How is the testing coming? Just curious....
Charlie
Yea, me too, but ran into a problem with the previous setup. The lever although great at initial pull, caused the slides to jam with two much sideways force above 20 degrees. So had to set up a new lever system that pulls almost straight up, works well with a manual test of full weights. Had other minor changes, but now all I have to do is add the stops to the base again and tweaking will commence. I will be sending pictures this evening and be able to give you some better stats for Phun. Maybe you can help improve the design, but my main concern is what piece will break first ;D
Regards, Larry
