New accelerating gravity wheel ! Converted video from www.newenergymachine.com !
Started by hartiberlin, May 11, 2007, 12:49:03 AM
spider4re
Quote from: bobmary on September 07, 2008, 02:49:28 PM
I have applied for a patent in Canada and US and since found out that the US shelve the application for 18 months then process it.
I have to wait about 12 more months for it to be processed.
Hello to all. Just like to say how glad I am to see the interest everyone has in my machine.
The machine I am referring to is the one at  www.newsourceofenergy.com . Lots of you say
it can't be done and others say how did you do it. As a matter of fact it was very simple and
I had help. George, a good friend of mine, who was an engineer since 1945 was very interested
in what I had done so far and suggested to try the cam and leaver mechanism that I used in
the unit in the short clip.
Now picture this in your mind. Get 2 weights that weigh 10 lb each and weld a strong rod
between them at about 25 inches. These weight are placed vertically on a track. One at center
and the other at the bottom The 2 weight joined together take less energy to move toward the closer
to the center you get. If you are moving the weights 25 inches you only have to move them 12 inches
to get to the 0 weight factor as centrifugal force does the rest. The first 2 or 3 inches are the hardest to
move. To do this, a strong rod 3 feet out from the center to the end of the circumference of the rotating
unit. This is were the pivot point is for the leaver to lift the weights. The actual length of the rod is 42
inches. A 42 inch rod acts like a pry bar36 inches to develop the force and 6 inches to do the work.
---------------------o---
36 inches            cl   6 inches
The 10 lb weight at the end of the 36 inch rod generates 30 lb plus 400 lb of weight from the wheel
rotating (flywheel affect) and with the pivot point 6 inches from the end , it can move a lot of weight.
The cam first moves the weights about 4 inches and then the leaver takes over and moves the weight just passed the center position. ( weights are equally divided in the center of the machine) Then
the centrifugal force takes over and moves the weights the other half of the way.
After this month I should have two companies, one in Canada and one in the US manufacturing them.
You can do a lot with a set of leavers.
Regards........Bob
Bob - is the goal to create a machine that will run a generator to power a single family home thus eliminating the need for outside power supply?
noonespecial
Hi Bob,
First, I want to thank you for answering my emails and I certainly join everyone else in welcoming you back!
I'm still a little fuzzy on how the actual lever is activated. Is it at 90 degrees to the weights themselves? I can certainly see how the 36" lever can lift the weights. You mention the 10 pound weight at the end of the 36" but that sounds like the lever is in-line with the weights? Can you explain this a little more?
Thanks so much,
Charlie
noonespecial
Quote from: spider4re on September 07, 2008, 03:40:35 PM
You should check out Bob's video on his website www.newsourceofenergy.com and you can see the incredible potential of his machine. This can easily run any generator and definitely eliminate the need for any outside power. The beauty is that you could even backfeed the grid (if allowable in your state) and end up getting a check each month from the power company!
Best regards,
Charlie
AB Hammer
Welcome Back Bob
I have only recently got involved and have been talking with Larry C for he lives in Louisiana as I do. I am a blacksmith/armourer  Here are some of my past projects http://www.creationtime.com/hisbsaw.htm  and on youtube I am ABthehammer where I have posted some of my past non working wheels to help people.
MY question is. Are you fully done with the design or are you still looking for better ways?
With out a dream, there can be no vision.
Alan
noonespecial
Here's my latest concept drawing based on what we know so far. Bob has confirmed that the cam is fixed and works as I thought from 3:30 to around 5:00 then the lever takes over. Larry, you might be able to modify your design in this way.
Best regards,
Charlie
