insane4evr
Quote from: gotoluc on September 17, 2008, 10:37:11 PM
....@everyone,
as mentioned in my above post here is the 220v inverter I purchased. I 'm taking a small risk here ($20. delivered :P) and going for a 150 watts inverter since Bill has said in the video that the consumption was only 100ma!!!... and that was using 120 volts!  so if that's the case I think a 220 volts 150 watts should do the trick. If not I'll loose a hole $20.  :(
Link: http://cgi.ebay.com/150W-Car-Charger-DC-12V-AC-220V-Power-Inverter-Adapter_W0QQitemZ250296515216QQcmdZViewItem?hash=item250296515216&_trkparms=39%3A1
Luc
Hi Luc,
Thanks for this find. I am jumping on this sparkplug testing because of yours and others posts, so I also bought one. I hope I get it soon here in usa.
gotoluc
Quote from: gmeast on September 17, 2008, 11:34:26 PM
Hi Groundloop,
What you said is incorrect.  I used reed switches because they were easy.  All triggering hardware uses the distributor's rotor with an optical chopper and gate triggering circuitry ... like one would expect ...NOT on the flywheel.  The circuit I posted was the "exact" circuit I used in the VIDEO.  That posted circuit is NOT the version that goes in a vehicle.  Please don't be so quick to find fault with others' contribution(s) to this effort.
Respectfully,
Greg
Hi Greg,
I think this is a misunderstanding ???... as I think Groundloop was just trying to guide this user to the simplest solution for now and not trying to find fault in your circuit. As we know and I have also posted and suggested for those who wish to have timing control your circuit is the simplest and most robust solution at this time. So I think Groundloop was just picking up that it still maybe too advanced for this user from the questions asked.
Luc
gotoluc
Quote from: insane4evr on September 18, 2008, 12:03:47 AM
Hi Luc,
Hi insane4evr,
good for you ;D  the more the better!  as everyone will have new ideas and together will help improve the circuit. This is the great part in open forum public sharing ;) everyone wins ;D
I order most everything I need from eBay and from different parts of the World. I'm amazed with the fast delivery of stuff coming from half way around the World. Most of the time it takes about 10 days.
Keep us posted of your findings so we can grow
Luc
Groundloop
@gotoluc,
Your are right.
@gmeast,
It was NOT trying to find fault in your circuit. You have a great circuit and I said that.
If you go back and look at my circuits for the 1,5HP project you will probably find
a LOT of errors there. :)  Sometimes English is a difficult language to communicate with.
Sorry if I hurt you feelings.
Groundloop.
gotoluc
Thank you Groundloop I think and hope all is clear ;D
let's move on!
@Groundloop, Greg or anyone else good in electronics, I have some questions.
Do you think it would be needed to have a higher frequency than 50hz?
If so, do you think we can take a cheap inverter like I just bought ($20. delivered) and modify it to a higher frequency?
If so, can one of you spend $20. and experiment with it?
My thinking is, since these are so cheap and maybe all we need for now, we could use just the circuit from them and add the circuit board we will hopefully create (once we test the circuit) which would have the coil, cap, diodes and mount it all in a new box which would have the HV wire leads ready to connect to the plugs. All in one box ready to buy and connect for those who can't build.
Let me know what you all think.
Luc
