zzzz
Dear Greg
I use super bug too, 1971, i try to do the same as your,
I have questions.
witch circuit you use now.
from your picture, look like diode seem parallel
not series like in nuxsus circuit?
Do CDI necessary? can I use normal point?
Thanks,
zzzz
ashtweth_nihilisti
Hi zzzz
No this is the  water plasma spark circuit,(not Bill's nexus one) and You can find Greg's CDI circuit in these pages, the energetic forum, or in the groups PDF :)
This PDF is listed on page one of the thread listed as being on the panacea university site
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panacea-bocaf.org
http://www.panaceauniversity.org
http://www.geocities.com/glorybangla/cqtes.htm
zzzz
rfsimoes
Hi all,
I had a hard time trying to buy 6A10 diodes but that was because I didn't know that a P600M was the same diode.
For those who have the same difficulty here is a link on the datasheet:
www.perfectway.cn/down/Datasheet/STD/6A05%20P600A%20THRU%206A10%20P600M-.pdf
Or just google for 6A10 P600M...
6A10 diodes have 250Amp Peak Forward Surge Current 8.3ms, and this is very important on these setups.
Now I have a question, can an engine run on ethilic 70% vol. alcohol? Does alcohol mix with water?
rfsimoes
rfsimoes
gmeast
Quote from: zzzz on October 03, 2008, 05:42:53 AM
Dear Greg
I have questions.
Thanks,
zzzz
Hi zzzz,
The circuit I am using is an adaptation of the very original circuit that Gotoluc demonstrated and then opened this thread.  In my circuit, the Cap is isolated and charged, then it is isolated again and then discharged to the coil as a pulse.  This can be done with a SPDT relay but the points will die early and can't cycle very fast.
If you could cram a second set of points into the distributor housing then you could use standard points to trigger the power Mosfets I use. But I chose to use a standard points conversion for VW's that replaces the points with a solid state sensor and then added an extra sensor ... one for Charging the Cap and one for Discharging the Cap to the Coil.
The Nexus circuit uses the standard coil, points and voltage then 'piggybacks' a plasma spark onto the standard spark using the standard spark as a 'starter' path for the plasma to cross the gap on .... like a Tig welding machine with 'high-frequency soft- start'... GENIUS.   I chose to use the original circuit concept and made it solid state ...  for science reasons.
Please note that my system uses much lower voltage to the Cap than other systems because of my choice of power Mosfets ... voltage limitations, cost, availability, etc.
Diode strings can be used in place of the parallel diodes I use.  I use 4ea. parallel per channel to get a higher current capability.  Because I use lower voltage, I did not want the IxR and/or cascading loss(s) of multiple diode drops in the long diode strings.
Two circuits follow and the third pic is a scope capture of charge and discharge trigger signals from the modified distributor.  My rendition of the original circuit is more difficult to make than the Nexus circuit but many here are capable of pulling it off:  Not shown are the 1A fuses into and out of the isolation transformer ... these are a "must-have" to protect the components.
***HIGH VOLTAGE***please be careful with ALL of this.
Peace,
Greg
