Someone did build a Tricoiler replica?
Started by mikestorm, September 19, 2008, 04:08:11 AM
mikestorm
HI Marks
are you saying that also if i put the inverter on an vehicle alternator with a voltage regulator built in, i can damage it?
mikestorm
Hi all
these are my news
yesterday i've made a coil with two wire of 0.51 diameter, twisted togheter, and about 31meter(100 foot).
now i'm looking for the right circuit
any suggest are pleased
thank's to all
Mike
Goat
Hi mikestorm;
Have you downloaded and read through the chapter 6 pdf as suggested by gyulasun in the previous post?  The information for the coils and circuits are in that document from page 6-10 onwards.
Paul
mscoffman
Quote from: mikestorm on September 25, 2008, 04:42:19 AM
HI Marks
No, If you are running a relatively powerful pulse motor on a battery in either the "charge" or "source"
position then connecting an inverter to the battery the pulses will damage the inverter. Pulses happen in a normal vehicle charging from an alternator but they are one shot kinds of things. You could also damage an alternator's regulator from a relatively powerful pulse motor attached to a battery.
:MarkSCoffman
mikestorm
thank's for the reply guys
1) i've read the chapter 6, and than i decided to make a first experiments, just to see if things works or not.
i've also read the short specs on the tri coiler wrote on youtube page.
now i'm waiting for the components, to make the circuit
2) the thing i would like to do is, a good pulse motor, with enaugh torque to spin a car alternator or a wind mill type generator(a little one), that gives me a 12/13 vdc, rectified offcourse, that feeds a set of a couple of battery, and at last power up my home light(the new low power) with an inverter, like magnacoster did.
thats all i would do, nothing more, nothing less
i've seen also that a normal inverter can be feeded by an alternator, for use pc in car and other light power things
am i travelling in the right way?
thank's
Mike
