Magnetic OU principle, You should really take a look at this !
Started by Butch, July 02, 2008, 01:01:34 PM
0 Members and 41 Guests are viewing this topic.
carbonc_cc
If a weight was added to the top of the washers (non-magnetic).
Would the free movement of the magnets passing by the washers become restricted because of the weight on the washers?
i.e. The resistance of the magnets traversal would be directly porportional to the weight on the washers...
The more weight, the more resistance for the magnet traversal.
wizkycho
Quote from: carbonc_cc on October 10, 2008, 10:30:43 AM
No, magnet pair doesn't "feel" anything (no reactance, no force) of what is happening with washers,
(but under condition washers are not oversatturated).
Wiz
carbonc_cc
I understand that to be true with the (un-saturated-magnetic) washers.
Due to the fact that they have magnetic properties the flux lines want to short circuit through them;
so they move into position without too much resistance.
But if a non-magnetic weight was applied on top of the washers, what affect would it have on the magnet's path?
I am unable to verify at this time.
Raui
This concept is simply amazing. Its so logical that I am amazed that no one has thought of this before. I wish you luck with all your work Butch :)
If you only knew the magnificence of the 3, 6 and 9, then you would have a key to the universe. - Nikola Tesla
http://ou-research.blogspot.com/ (Feedback appreciated)
Ergo
Quote from: wizkycho on October 10, 2008, 10:29:22 AM
you are again rude. why ? cause you are blind - it is your choice
I'm not rude. I'm just asking you over and over to explain the 50:1 ratio. So far you have not explained how this is obtained.
Even much simpler english then mine is sufficient to describe to smart open minded how it works.
draw yourself better picture , You are the one that reffuses to understand. Like a child (they are ok, but You should now better)
I cannot draw any conclusion on this contrapment until you finaly manage to explain the 50:1 ratio.
You clearly see something I don't, but you can't or won't explain this to me or for the rest of the folks here for that sake.
protocol for good behaviour of Yours:
In the future You must say Why something is not working, and not just spit if you don't see it at first.
I have never spitted on this device but I have questioned on how the 50:1 ratio is being obtained.
Somehow you refuse to answer how you calculate the 50:1 overunity from this device.
After you truly see it
you must admitt that You were blind and at least say thanks - cause I made an effort to make You See.
Stay Ignorant ! If you wan't or say thanks I see it now. Don't waste My TIME by NOT addmitting YOU WERE WRONG.
other way you'll be more and more wrong.
More and more I'm starting to feel you belong to the "belivers" that have had a revelation but you can't explain it for "non believers"
But as long as you belive there is hope.....in your world....so to speak. It's like a religion. You just have to believe....
If I'm wrong in my last statement, then for gods sake, please explain how this device is 50:1 overunity.
