Is Lindsay?s ?SM? a fraud?
Started by RobotHead, May 19, 2008, 11:55:42 PM
Grumpy
Chef,
Come on, have a drink with me...
"vamos a echar el trago"
        -Frank Edwards
giantkiller
A quote from the latest Indiana Jones movie:
Indy's friend, Mac, asks where do the aliens go?
The Oxley, the older professor, answers: 'Into the space between the spaces'
--giantkiller.
wattsup
Geez, Is the storm over yet. phewwww.
@sparks
I will look on the net for old dental x-ray machine parts to see if I can find such a toroid.
One question though. You say the black wires are hollow tubes but when you look at the FTPU they are connected. Could their connections be a distration? Then on the LTPU, each black is connected to a white. Could this also be a distraction? Hmmmmm.
@otto
With my recent purchase of a nice big pulse generator (PG) going from 1hz-10mhz and 0-100 vdc, I am now testing things so fast and easy. I no longer have to worry about mosfets, etc., as you know that part of this work was my main problem and slowdown. Now I can test so many different transformers, coils, etc., and I am learning much faster with my trusty oscilloscope and compass. I am also learning more about the FTPU outer coils and ring, there is a coupling action from the coil to the ring. So you are not alone. At least 2-3 hours per day I am on this, plus reading and reading everything possible.
Overunity will not happen in a one two step. It will require many steps and each step has to be discovered and understood. We are all pushing on certain aspects of this and eventually it will all come togther.
For those who lack the EE skills, there are many FG's and PG's being offered on Ebay. If I could, I would buy them all but three in enough for now. lol
@GK
Liked your post. Thanks. Leed was the man indeed. Seems this man jumped right out of a Jules Verne novel.
Neolystic
@wattsup
Well now I know who's been bidding against me for FG's and PG's lol
sparks
     SM  built himself a magnetron and tuned it to the emwave field the Earth emanates.  You bust an electron loose in a vacuum it is not free to go where it wants.  You have a positively charged plate at the other end of the tube or just plain old gravity force.  (one in the same) the electron starts to accelerate parallel with the field.  It would go straight like a rock dropping but there is this other force to deal with.  It is the omnipresent magnetic aether flow.  If the aether flow is perpendicular to the other force field the electron will veer off.  If we stop the other parallel force the electron will continue to veer and it's centripedal force will cause it to close in on it's own track and it now drifts cw or ccw in an orbit depending on which way the aether was flowing and in which direction the electron's motion was initiated.  Sm knows this unless he is a total idiot who never worked electronics,  which seem not to be the case.  This hall effect is well documented and can be explained by the coriolus force.  It's the same shit that gets hurricanes spinning.  Now a betatron makes sure that the electrons veer just enough to remain inside the torridal vacuum tube and form a current  driven by the energy of the electrons coming out of the filament.   So when SM puts his weak ass magnets in his first line of shit,  the ripped off betatron gets some voltage because he is using the permanent magnet and gravity to drive the cold cathode betatron.  Ooo voltage no current  and it goes away when he flips the shit over cause the parallel force in the betatron just changed.   Then he asks can you explain this.  I just did.   Then we go up to model two which is a microwave oven core all fuckedup.  But it runs on feedback circuits and lights a couple of bulbs.  Remember betatrons can go up to millions of volts from a 120volt supply so how much voltage do you need to get up to the 120volts going to the bulbs.  Not much.  The shit just keeps getting deeper and deeper and SM can't get anybody to buy it cause the thing already belongs to GE since it's inception in 1940.  Sorry SM you reinvented an invention.  Impulse energy that results in electron orbital momentum converting to conventional electron motions we know as electricity.  And all you have to do is use pulsed voltage.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
