Is Lindsay?s ?SM? a fraud?
Started by RobotHead, May 19, 2008, 11:55:42 PM
Grumpy
Just got a pic that looks like it might be a travelling wave of aether hitting on an RE detector - got to go, but this has been great guys.
It's good to share rather than be so secretive.
Grump-steins Dungeon will be roaring tonight.
        -Frank Edwards
Spider
I agree, this is better!!! :)
I had no idea that so many are working on this version of the tpu.
I have to go too. Keep up the good work everybody!!
Spider.
When a magnetic field, produced by a moving electric field, is moved longitudinally a tempic field is produced.
innovation_station
this is what im useing for bifillar coils
or primary and trigger
i will use fets for single coils ...
ist
this is my mkc circut kit assembled :)
bolt
For as long as you all keep banging coils with spikes more years will pass with NO results. The TPU works off pure sine waves to provide the initial magnetic rotation of a weak magnetic field.  The energy required is extremely low it does not need 20 amp power supplies a 9 volt battery is enough.
How to make a rotation field? EASY make a Rotoverter that takes 110 AC sine wave and produces a PERFECT 3 phase magnetic circulation right off the bat with 3 or 4 components fed from a single phase AC sine!
When you have this you make another one the same and place it below the other one and do the same with a second frequncy. Now we have 2 circulations in perfect resonance but  slightly out of phase to each other. The out of phase produces a third heterodyne but now we have TWO rotating magnetic fields slightly out of phase produces a magnetic rotating BALL! How many of you have made a stacked tpu and actually made a rotating magnetic field?? I haven't seen ANY not ONE.
Each tuned circuit loop is half of dipole folded and the voltage will appear between the dipoles. The interaction of the rotating ball at the right frequency will interact with the earths magnetic field as because its spinning it will have INERTIA and will resist being moved as a gyroscope!
The circuit is also a cold cathode triode tube! The 3 coils around each collector are the control GRIDS the first collector is the ANODE and the bottom one is the CATHODE. Electrons will stream between the Cathode and the Anode (maybe reversed in cold electricity) of the folded dipole. When SM told you to use tubes it was also a cryptic clue as well as practical to make low noise pure sine and also said you do NOT need a heater to stream electrons of COLD electricity.  He also told you he made a 3 channel AUDIO amplifier of great purity. ANOTHER clue. He also told you the frequency was based on circumference of the collectors!
He told you there are THREE control coils not 8 5 20 or 50! One for each channel of his cryptic 3 channel hifi  system.  Also he said the best designs used 3 collectors but this gets sketchy because its clear the simple TPU use two collectors one anode and one cathode but can be stacked to increase current or voltage between then like stacking batteries.  He named them collectors for good reason too because they collect the streaming electricity which will appear like magic once you have a spinning magnetic ball of high purity.
You should NOT be making high voltage tesla coils or pancakes or HV generators that is not a TPU and has no place in this design. High voltage energy spikes of a few uSec at 1000 watts  as in the big TPU no way you can rub your hands round it and not get whacked in face and arms stinging like hell anywhere in the room.  Also SM told you there is NO mass circuitry he is right is needs 2 oscillators and some old 80's tech VCO feedback to keep it locked. So why are you making hi tech CPU controllers for?
The extremely low power to start the TPU is due to the fact it only requires simple sine oscillators these are the PRECURSORS.  This will produce the tiny magnetic field weak at first but as it interacts with the earth magnetic  field this FEEDS energy to the system.  As magnetic energy builds the earth responds by inducing more current in the collectors to resist the action. It feels like a motor spinning with a flywheel and wont like being moved and the phase offset creates the low vibration.  Electricity is now a by product you only have to find and tap the right places.
As SM said it RUNS with self gain and only a tiny sniffer coil is required to power the control circuity and like all ZPE devices the most critical of any design is making sure the load does NOT effect the input as NON REFLECTIVE. The TPU easily achieves this as high currents passing around the collector coils are perpendicular to the control coils and the entire format is a Class C Three Phase Magnetic Resonance PUSH PUSH Triode Amplifier.
Because its two triodes one up and one down this separates the voltage between the collectors. The higher the magnetic ball power field the greater the separations and resulting higher voltage appears between the dipoles and the more stress and heat builds up in the system. The lower side will force negative and top side positive thus only DC will appear from the device. BUT its actually high frequncy DC with an AC component.
So clear your bench throw the old trash out and start making collectors with SINE waves which will spin a compass needle .  Then make TWO and stack them and observe the relationship of the magnetic fields. When you hit the right frequencies and start shaking magnets some distance away of the loops with tuned collector caps spinning like hell then you should get ready for a big bang!
Im telling you this because we are running out of time before the planet is nuked.
innovation_station
and the big bang comes from the man made magnetic sphere synicing with the rotation of the earth as hammel has done  :o
hit 7.8 n call lightning??  this is like sound and the sound barrier
sorry bolt
i do perfer the cascaded cold way it apears safe and remains compleatly cold  ;D
ist
keep it simple stupid!!   remember that motto ;)
@bolt
what you describe apears to me to be a plasma force feild bubble  ;)
not such a bad idea if we can get it to work safely.... :)
