Upgraded Bedini design with a 212% efficiency rating?
Started by nightlife, November 12, 2008, 10:54:20 AM
nightlife
 I have a upgraded design of the bedini that is much more efficient then the bedini it's self. It utilizes both poles of the magnetic coil and they fire in the middle of the gap between two magnets with like poles facing each other.
Take this picture for example. You put one coil inside of one side of a tube and another in another side of a tube with that has the magnets attached to the inner side wall of the tube that also has two dividers with a bearing in the middle of each with a non metallic shaft the bearings ride on so that the tube rotates and the shaft and coils stay stationary. The coils polarity's must be switched between each pulse to insure the coils core doesn't become magnetized as well as it will flush out all of the current left in the coil forcing it to the charging battery's.
This design utilizes both poles and allows us to utilize the full potential of the repelling magnetic fields by compressing the field together so that the length and strength of the field is equal allowing us a longer and stronger repelling affect. This quadruples the torque using the same energy that is used in the basic bedini school girl design which should add 4 times the efficiency rating of the bedini school girl designs torque which is said to be 53% efficient.
Let me know what you think.
So you just multiplied that 53% by 4? That's a bit short sighted don't you think. Build and share the results please  ;).
