EL IEVE free energy magnetic mill
Started by CLaNZeR, September 27, 2008, 01:37:40 PM
open maind
THIS IS A CORRECT POSITION DE MAGNETS IN THE RING
Jdo300
OK, this has gone far enough. It is one thing to have a debate and/or disagreance with people but it is another story once you start to openly slander someone. I can confirm what Dan has said about Juan and I have contacted Stefan to request that user "open maind" be banned and that this thread be locked.
It is pointless banter like that that gives this forum a bad name and as one who has been here since the start, I think everyone here will agree with me we've had enough of this.
God Bless,
Jason O
nievesoliveras
open maind
hello    the correct position the magnets in the ring
open maind
Interesting though that this is from Juan Carlos Aviles Moran who discovered the cascade of physical phenomenon called magnetic repellency back in 1980!
Exhibition of draft unit magnetic repellency
molecular composition of artificial magnets or alloys (magnetic fields increased or magnified) = torsion strength and speed
Our purpose is the construction and implementation of the new system of alternative energy Repellency Magnetica Unit (MRU) this device) this device due to the simplicity of its structure, it is easy to construct giving a rapid response to the need energy, so limitless, clean and without consumption of other energy that does not come from the same operation.
The MRU was placed in first position on the other alternative means of generating energy, such as fossil fuels, biofuels and blends, the MRU does not pollute the environment, not to lay off toxic fumes, this device uses just two types of various combined forces, which are: the CRM (WATERFALL repellents MAGNETIC) and FC (CENTRIFUGAL FORCE).
Also this project is on the other alternative methods of clean energy such as solar, thermal, geothermal, hydroelectric, wind, marine engineering, and so on. These methods are subject to the variable weather conditions, wear of materials being subjected to extreme temperatures. The MRU has the ability to avoid the erosion of their own pieces, by creating a magnetic field repellency between its major pieces, extending its life by this condition.
DETAILS OF THEORETICAL DESIGN:
The MRU consists of an orbital rim or firmly attached to a base, the diameter of the ring is related proportionally to the size of the shields (ERM) who are predisposed unidirectional in its interior. This succession of shields must all be located in the direction of a single pole, negative or positive.
The magnetic propeller (HM), which revolves subject to its own axis inside the ring, consists of shields at the ends of magnets or face to face with almost rozándose shields predisposed to the hoop, to turn the propeller, the coats of inside the ring as of the end of the propeller must repel each other, ie signs repel them, starting immediately a force of repellency between the coats that make the propeller rotate in one direction, after this initial force begins A second phase of FC that as the size and weight of the shields at the ends of the propeller, will give an increase in revolutions or money orders. This, to provide a force of torque on the propeller shaft that is the resultant force we use to move any motor or dynamo electric generator, staying with the option to obtain a percentage of extra power when connected to return to ring and thereby induce them to the greatest force shields repellency. The MRU has the unique ability of its self-same energy and discharge it into higher energy repellency to the shields.
The MRU is not capable of generating electricity itself, but if you run through the magnetic repellency a mechanical movement which is to rotate its propeller getting a force of torque according to its size, purity and shields percentage of cargo downloading.
CHEMICAL COMPOSITION OF THE MATERIALS
It is important to mention that the basic raw material of which shall be composed our shields reflectors repellents are the iron of high molecular density, some of them being the most suitable manganese steel or steel tuxteno, also known as iron ore stone imam (Fe3O4) as well as those arising from the magnetite.
Shields reflectors, must be manufactured from a high purity metal, to have more repellency when provoke the cascade of magnetic repellency.
This whole exercise is born engineer to apply the laws of physics, molecular and chemical properties that are subject to the materials of the MRU. The MRU emerges from a comparison with the water mill, we will make note that this device is a mill in which the flow of energy is not lost at any time but completely surrounds the mill, closing a circle that we call the infinite cascade Magnetic repellency, which is to be the fuel of the MRU.
Meanings: MRU Unit Repellency Magnetic; HM Magnetic Helix; Aro or Circle; Repellency Magnetic Shield ERM, CRM Waterfall Repellency Magnetic "
"The unit of magnetic repellency MRU created and designed by Juan Carlos Aviles Moran is the alternative means of generating electricity in a very economical the MRU is a mill or repellency magnetic power that turns the shaft of a dynamo. He was in 1980 that juan Carlos Avila moran develops uses magnetic fields between magnets magnified magnetic polarity.
the unit of magnetic repellency MRU mill or repellency magnetic MRM is an alternative to producing electricity and is very easy to build by giving a solution to the energy crisis worldwide, the MRU works with the same principles as a water mill (hydro - Electric) or wind (wind-power) but in the MRU the mill will move by magnetic force repellency (magnetorepelencia-electric)
Juan Carlos Aviles Moran discovered the cascade of physical phenomenon called magnetic repellency this is a unidirectional magnetic force repellency carried inside the rim of the unit of magnetic or repellency mill magnetic repellency, the cascade of magnetic repellency is nothing more than a trail of repellency by continuing where the magnets pass the rotor shaft of the MRU to be repelled by the ring magnets; cascade of such serious repellency magnetic energy shock of water in a windmill THE COMMON "
