It's just a 12v 2A/6A Battery Charger Circuit
Started by frog, November 26, 2008, 10:46:07 PM
frog
NO MAGIC, NO VODOO, NO NOTHING SPECIAL.
TAKE A 120VAC TRANSFORMER WITH DUAL 12V OUTPUTS
RUN THREE LEADS FROM THE RECTIFIER IN YOUR ALTERANTOR
TO A THREE PHASE RECTIFIER OUT TO THE PRIMARY OF THE TRANSFORMER.
NOW RUN THE LEADS FROM THE OUTPUT OF THE FIRST SECONDARY THRU THE 40A 600V PIV
THEN INTO THE INPUT OF SECOND SECONDARY THE FIRST LEAD FROM THE FIRST SECONDARY
IS YOUR POSITIVE TO THE CELL, THE SECOND OUTPUT OF THE SECOND SECONDARY IS
YOUR NEGATIVE TO YOUR CELL....
UGH...I'VE SPENT THOUSANDS OF DOLLARS ON THIS DAMN PROJECT. AND ALL I HAD TO DO WAS
TAKE APART ONE OF MY OLD BATTERY CHARGERS. FUCK SURE ENOUGH, THERE'S THE SPECIAL
VIC (VOLTAGE INTENSIFIER CIRCUIT).
ALL FOR NOTHING....
"When you change the way you look
at things, the things you look at change."
pese
