locating Steve Mark´s TPU demonstration house
Started by EMdevices, November 22, 2008, 09:00:43 PM
Neolystic
@EMDevices
The truth always has great value, whether we like that truth or not.  Even if SM's TPU obtained power from the grid, that doesn't necessarily preclude using those same principles of operation to create power from natural sources such as gravity or the Earth's EM field.  I'm not saying either way because, until we hold a working TPU in our hands, none of us can really say 'for sure' what it uses for power.
My most recent research suggests that there is a 400 HZ-wide band that resonates with Earth's EM field to produce a tiny amount of excess power with each pulse.  I'm currently waiting on parts to build a circuit that @Groundloop designed so this effect can be magnified and verified.
My point is that, even if SM's TPU tapped into commercial power, your information takes us closer to understanding the TPU's operating principles.  Those principles can still be applied towards tapping into natural sources if they exist.  For this reason, I very much appreciate your work in this area.
Neo
starcruiser
I am with Em and Thaelin that the TPU is a resonant device. I am thinking it is a couple of tanks linked together, Look at a three phrase motor design, a "Y" configuration with a capacitors applied to it like a Rotoveter. You get 3 tanks circuits this way. Tune the primary tank to a base frequency and the second to a multiple, maybe a third above, make sure the choosen values combine in the third to a say a fifth above the primay. Use low ESR caps. Use a magnet as a field source to couple the tank to the 90 degree bifilar coil for a power tap. Use a local oscillator to tickle the primary tank circuit.
Power generation is due to environment participation, tank Q and a rogue wave theory. Output would contain some of LO signal in it. Does this sound like a active front end to a old receiver?
Power Output = Q of tank plus the multiplication factor of 3 tank circuits (4 x 4) mixing, won't this produce a bit of power?
the small torrid in the SM TPU is a colpitts oscillator (or similar) that is sync'd to the tank circuits via proximity.
Just a thought... What do you guys think?
Carl
innovation_station
otto
Hello all,
@wattsup
Cryptic language?
No!
We are living in a sea of energy. This is the truth and our TPU IS already immersed in a highly charged
environment. The particles are charged!
So, our job is to give the particles a rotation. The faster the better.
You all know the Tesla patent 685 957 Utilization of radiant energy. A plate collects the particles.
He was able to collect them and use this energy. The best is that this invention works. It works so good that you can be killed by the collected particles. No further comment on this!
We are also collecting such particles with our TPU. The more we rotate them, the more we can collect so our tornado is bigger and bigger.
If you think Im wrighting about something virtual then youre wrong. I see what such particles can do, I see how strong they are, how inert, I saw their kinetic energy....and, if you disturb the rotation of the particles you have a disaster!!! A disaster in the sence that the current rises a lot.
Did I say that Im researching the particles? Yes, but nobody cares,ha,ha.
1.why not more then 2 1,5V batteries?? Dont we see a "hided" 9V battery in one of the TPUs??
"Hided" because a little child would know that there is a 9V battery.
2. to get 60V without a load?
Didnt SM told us that if we connect a load, the voltage dropps?? Dont we see in a video a voltage of 90V or so???
Where did you get the 0,01V??
The TPU has NOTHING to do with power lines!!!
Otto
tosky
We all know that magnet will induce current as electricity. But where the physics tell that particle could also generates electricity? So where is the theory?
