Thane Heins Perepiteia.
Yucca
@Sparks,
I see what you mean, so a really low impedance (effectively a short) needs to draw on the HV coil for it to, dare I say cavitate. I wonder if putting a beefy really low ohm current shunt accross the HV coil would be a first good step in single toroid research? Then the power through the shunt could be calculated and see if Pout/Pin can be made higher than a regular trafo by using certain drive signals.
One crazy thought I had is to close loop a single toroid: connect the HV output coil directly to the HC (high current) input coil through a low impedance saturatable reactor. Then the HV coil and saturatable reactor combo may introduce enough delay to the HV output pulse so that it could hit the input tank at zero crossing and thus pump it. If the whole thing was tuned correctly maybe it would selfrun after starting it with a pulse from a precharged cap. For power takeoff perhaps a second HC coil could be wound under or over the HV windings. In such a scheme even small phase lag or lead problems with the feed back pulses could cause heating problems. It wouldn´t like to power reactive loads. Hmmm sounds quite TPUish.
i_ron
Quote from: derricka on January 26, 2009, 09:09:17 PM
Yup, that would be the software for me. How did you know?  I've just finished illegally downloading it from SleazyTorrents.com . Thanks big T.  ;)
LOL, RIGHT ON!!!
sparks
@Yucca
    And cook coils too.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
ffonz
Quote from: sparks on January 26, 2009, 09:57:03 PM
@Yucca
    And cook coils too.
Speaking of coils.. and efficiency etc.. I wonder if this
link has anything of value to contribute toward moving
the fascinating work you are all doing in the direction
you are aiming for?  I hope it contributes something..
even if only a new idea or concept?
http://peswiki.com/index.php/Directory:Keppean_Scalar_Motor
I haven't a clue what you guys are doing quite frankly
but I look to the day a usable product emerges. In the
meantime I enjoy my regular visits to see 'what's up'
and appreciate the opportunity to be fascinated by it all.
ffonz..  8)
woopy
@Thane
Hehe...good news ....can i choose the color of my coils... next week;D
@Yucca
very nice small outrunner "et vive" the indoor flying !
@Thane and Ron
my two cents if you intend to drum the Perepiteia
