Finally I think I got it !
Started by Gravitator, January 27, 2009, 12:26:13 PM
Joao
Quote from: hansvonlieven on January 29, 2009, 09:19:21 PM
A 100 kg of anything is still a 100 kg; why the distinction between weight and water?  ???.
Hans von Lieven
Because to lift 1000 kg of water utilizing for instance 100 kg of  stones by negative presure  will resolve the water pumping problem in the world. The input (100 kg) will be 1/100 of the output (1000 kg). Or no?
I think some are suggesting something like the attached drawing. To be honest my head is going to explode with all the hydrostatic pressure crap so I'm going to lay off it for a bit.
hansvonlieven
Quote from: Joao on January 30, 2009, 03:13:38 PM
100 times 100 equals 10,000 not 1000
Hans von Lieven
rlortie
Related interesting link!
http://www.svpvril.com/Water.html
Some here seem to have a problem understanding displacement by weight verses displacement by volume. Is it on the bottom or on the top?
Ralph
truth
Quote from: PhiScience on January 28, 2009, 02:29:58 PM
Gravitator,
I just did a little test of your setup with some very gooooood ;D results.
I took a 1-1/2” bore pneumatic cylinder and hung it 5-ft. above a bucket of water, using a ¼” air hose I put one end of it into the water and the other end I attached to the top of the cylinder. With the cylinder fully retracted I hooked a 5lbs weight to the piston rod of the cylinder and it had no problem drawing the water up and filling the cylinder completely.
Thank you, Gravitator
Wayne
There is something important missing from this "test" and that is the stroke of the one and one half inch pneumatic cylinder. Without knowing the stroke distance the volume cannot be calculated, and that is a BIG problem.
100 KG weight lifting 1000 KG water is a ratio of 1:10. Let us just go for simple overunity at 1:1 and think about 5 lbs of potential energy lifting 5 lbs of water to the same height as the initial 5 lbs potential.
1 Cubic inch per 0.036127 pound  =  The weight of water
5 lbs / 0.036127 = 138.4 cubic inches of water
The radius of a 1-1/2 inch bore cylinder is 0.75 inches
0.75 times pi 3.142 = 2.35650square inches
138.4 cubic inches / 2.3565 = cylinder height of 58.73144 inches
So in order to fill that cylinder with just 5 lbs of water it must be VERY near 5 feet long.
Now for the unfortunate reality of this little 'test".
The vacuum pressure IS proportionate to the radius of that cylinder and the amount of weight, so that a larger diameter cylinder requires more weight to produce the same PSI vacuum.
Good try anyway.    ;)
