Towards Realizing the TPU
Started by poynt99, September 03, 2008, 08:46:35 PM
forest
Faraday unipolar dynamo is a device which is using such principle at least that is an explanation I found. Electrons in rotating copper disc are speed up by magnetic field interaction and current show itself between shaft and an edge of the disc. It's a closed conductor surface, and also  because of that it is inefficient. Some currents are used up to heat disc because they are flowing in closed path.
What if the same concept is used within TPU for collecting current generated from rotating magnetic field ?
Of course here it's not a disc inside (could be also) but Tesla has given improved schematic of unipolar dynamo with disc shattered  into separate not connected areas.
I think to build TPU we should :
1. Implement efficient rotating magnetic field around ring with high speed
2. Implement collecting coils , maybe based on Faraday unipolar dynamo concept
otto
Hello all,
@Mannix
I pulsed a core. Result, wonderful light.
I pulsed only the collectors. Result, wonderful light.
I pulsed a combination of 2 collectors AND just 1 core. Result, best light so far. With a current of say 2A at 20V. Yes I know. Its a lot of current. No, the light was not full lighted. The point was to see how I could use the core. Of course my core is on 1 end open. When I shorted the core I saw the current rising and then I  lost the light.
In the past I pused all kinds of transformers and feeded the signals into the TPU coils. I wanted really big signals. I also tried it with a camera flash unit. It worked great but at lower frequencies then we need.
In this moment I have connected my controls in series with the collector.
Now people imagine to pulse a control coil and the result is feeded into a collector. Have you all enough imagination??
It seems that a nice adventure is waiting. If I fail - no problem - then I have made something wrong and there is no way to be dissapointed. Im not the brightest "lamp" here, ha,ha.
Otto
Mannix
Quote from: forest on February 02, 2009, 03:25:49 AM
Yes,
but we will need near light speed particles and its the tubes that are the only things with a chance to deal with them.
A rotating mag field I believe is secondary to the particle accelerator which is running at incredibly high speeds in a circle ...which are simply beyond the design paramaters of ss and accidentally/fortuitously   within the characteristics of many tubes which produce particles  of high speed and who really knows how high in different conditions than those for which they were designed.
Its no surprise that ss had taken over for so many things because "WE DO NOT NEED THE SPEED ANY MORE" in energy using devices ..do we?
http://en.wikipedia.org/wiki/Betatron
forest
Now it's clear why TPU does not work when turned  back. It still works but no output, no slowdown electrons appear . Betatron needed an electrons source also. Does copper wire contain enough electrons or must be filled up before speed up action occur ? I'm sorry Mannix that we are so dumb (I am  :'()
it may be interesting for you that I'm quite sure Hubbard used the same principle and magnetic fields are crucial for that action, but that's my personal opinion.It may be interesting because Hubbard used different embodiment which could potentially eliminate problems with core heat and frequency limits.I state that because apparent output from his little device was much higher then TPU.
forest (Dumb)
Mannix
Nobody is dumb we all are learning (hopefully)
Much of the info is only now ringing all the right bells . I do not know why I was  so slow to make the right connections.
Gray, hubbard ,moray, sweet.,.etc etc the only exception is hendershot who had something a bit closer to Stevens devices
they all rely on what I will loosely call dilectric action......did you know that static discharges from unrolling sticky tape  produces xrays?
None of this means that any of us will be able to build a tpu...but we should at least be using all of the specific clues given, and the most important one is the bottles IMHO
