HydroMeyers Vic
Started by Spewing, January 31, 2009, 03:02:14 AM
turbo
Quote from: TheBuzz on February 10, 2009, 04:31:38 AM
Getting rid of people that make false claims and accusations is never a waste of time Marco. Perhaps if we spent a little more effort doing it, the free energy movement might have a little credibility.
There is something about the word free that tends to draw certain people.
I know this, but you cannot get rid of them, because when one goes ,two new come !
But i have faith in our new fulltime moderator  :)
Marco.
Grumpy
yeah the use of sacrificial metals is old.
gas/UV/plasma - check yer mail
        -Frank Edwards
dankie
The_Buzz , wrong again ... Trying to discredit me and overcomplicate things ??
The VIC pictures I posted is the VIC for the injector , it is the one and only VIC , it was NOT used for the gas processor ...
And yes , it was made with either 430F or 430FR wire , my wire has 20 ohms per foot but is magnetic and has very low coercivity , it will act as core material and provide higher voltage while restricting amp flow to 1 milliamp or lower . YES YES AND YES !!!!!!!!
Heres a quote from the tech brief ...
Heres some quotes from Dynodon , somebody who saw Stan`s stuff many times .
Quote 1 :
The bobbin size I wrote in the first post.2 3/4" od x 3" long with a 3/4" square hole through the inside bobbin.The outside bobbin is for the secondary wire.Each groove is filled one at a time.Fill first one then jump to second one and so forth.The smaller inside bobbin holds the chokes and the primary.The two chokes are wound at the same time side by side.You follow the same path as the secondary.Fill the first then jump across to the next and so forth.Then you wrap paper over top of the chokes, then you wind the primary on top of the chokes.This wire goes from left to right then back from right to left.One row at a time until you get what you need on it for your primary coil.Then this bobbin slides inside the outside.The bore of the outside bobbin will be @ 1 7/8" dia.All grooves will be 1/16" wide.The webs between the grooves are @ .070".As for the "X" marks in the VIC coil drawing figure 6-1,they only represent the area of the cavity to fill.Not any reference to direction or crossing of wire.Longitudinal wrap means left to right,and bidirectional means one way than the other(Both Ways).And yes the chokes need to be stainless,buy yours from dankie before it's gone.
The aluminum box it's in is the back half.Then the front cover as seen in the previos picture,goes on top of this one.The high voltage lead comes out of the hole and the input  goes into the 15 pin block,and yes it's the same as a PC plug.
Don
Quote 2:
There are no more pictures,and I won't be able to get any more.Everything is being sold to Orion.I won't get to see it again.As you can plainly see,the core of the coil assembly is a EI laminate steel stack.There isn't any ferrite rods in this core.That picture is the whole VIC coil in one.And yes Steve this coil is intended to be used with the Injector system.After all it is in the memo 425 for the Injector System.But I do feel that it is the lastest version of the coil that could be a direct replacement for the earlier models as well.You would just wrap the primary and secondaries as needed.This coil would be wound for higher voltages,than the tube cell needs.
As for starting the car,it isn't all together.Some of the components were taken off,by the previous owner.This was done to split up the system,so if the buggy was ever stolen,they couldn't get it to work.All of the pieces are there to put it back together.The buggy was set up with the injector system.But Stan never got to finish it before he died.It was said that he was able to get it to fire but not run.There was an issue of timing everything.The current owner doesn't know how it works and has no desire to put it together or have anyone else work on it.He just wants to sell it.So don't ask why he doesn't do anything with it,he doesn't have time or money or the desire.
Don
johnbostick
There is one who is arrogant, conceited, self-important, vain, smug, high and mighty, stuck-up, snobbish, haughty, snooty, puffed-up, overconfident, egotistical, narcissistic, self-centered, bigheaded, vain, pompous, pretentious, self-righteous, overconfident, brash, bombastic, verbose, long-winded, overbearing, grandiloquent, supercilious, condescending, disdainful, scornful, ostentatious, brazen, flamboyant, loud, flashy, gaudy, glitzy, lurid, turgid, dull, stilted, grandiose, and delusional, you can’t fix that.
Just because you don’t see it doesn’t mean it’s not real.
ramset
John
I have to check but you could have the record with that insult [its gonna be close]
   Chet
Thanks Grandma
