Play inertial "trampoline"...
Started by iacob alex, November 17, 2008, 08:46:51 AM
iacob alex
              Hi!
    The mechanical balance wheel(see the mechanical clock,,the little wheel and the tiny spring) is out of question here.
    We are looking not for a swinging motion(to and fro,see-saw or Milkovic's arrangement type) but for a continuous turning,revolving one(with the same formal far-away "visage" of some water or  air flow captors).
    So ,the first problem is to imagine in a simple way...an unbalanced set,to let it fall(as in a real,visible flow) up-down(semicircle trajectory).
    Let's say,that we begin with a long arm-short arm scheme.
    It is an uninterrupted fall motion to gain more kinetic energy(rotational inertia).
    Only when we have sufficient energy(the bottom point of the free fall) ,we must release a short -time "trampoline" type motion,so to "reamake" our starting unbalance,on the same side of the fulcrum: ...again the long arm-short arm scheme.
    The "trampoline" play is a proposal only,and appears to be as a secondary problem.
    So,can we hope for a "self"?!
        All the Bests!  /  Alex
iacob alex
  ...something that ,maybe when you was a  child ,it amazed you at the circus show.
     What I call "trampoline effect" is not really a trampoline,but something alike.
     So,a "trampoline effect",as I intend to suggest,can be that well-known stunt,performed by acrobats using a "see-saw" apparatus(in fact,a simple lever).
     Usually,two acrobats drop from a certain height,onto one arm of the lever,on the other arm,a single acrobat is launched twice as high into the air.
     We can understand that the lever in a very short time,transfers the momentum of the two acrobats into one acrobat,sending him twiceas high.
     This leap,spring,jump ,hop is quick as a flash motion ,that can help us to organize the long arm-short arm switching process,after a "full"(0* to 180* degree) accelerated fall.
     Sure,this process can be designed as a mechanical power transformer(lever),or as an usual electrical power transformer.
iacob alex
            Hi !
   The proposal  for  a  " trampoline effect",is that of a self-switching method ,possibly useful in a long arm-short arm classic arrangement.
   A trampoline is usually a frame with springy material on which people jump up and down...
   Here, the trampoline material,frame  becomes ...a simple lever.For this reason,I said "trampoline effect",and we are interested for the jump up motion,only.
   If you take a look at    www.geocities.com/iacob_alex/Stellarotor.html     and then click on "Some Drafts"/pos.42-48/Free Gravity Rolling 1-6 ,you can make your "movie".
   So,in my opinion some comments(..."a swinging rock"....."a balance wheel in a mechanical clock"...) can be digested as a misunderstanding...but others(..."nothing special there"..."this kind of thing has been around for a very long time"...) made me think in a different mode:...for some people a "skeletal" idea means nothing:a question of style,manner to work side by side in a forum-team.Sorry..to be in the wrong place.
         Anyway....All the Bests!  /  Alex.
iacob alex
  ...if you take a look at    www.geocities.com/iacob_alex     then click on  Some_Drafts/text047.jpg
("Trampoline"  Pendulum).
iacob alex
.....if you take a look at :  www.geocities.ws/iacob_alex/Some_Drafts/text047.jpg
.....as a possible self running arrangement (lever,pendulum,launcher ) , playing a continuous unbalanced  lever ? !
    Al_ex
