Towards Realizing the TPU
Started by poynt99, September 03, 2008, 08:46:35 PM
Magnon
Quote from: -[marco]- on February 21, 2009, 06:40:01 AM
Hello Magnon.
If you had used the search button you would have found we went over this two years ago.
Here:
http://www.overunity.com/index.php?topic=2169.msg32792#msg32792
And Here:
http://www.overunity.com/index.php?topic=3403.msg53303#msg53303
Even the phonon calculator was posted two years ago.
You seem to be pretty sure about your statements.
I on the other hand do not think your view has got anything to do with the TPU.
@All
Here is a fresh document i have just created about the true inventor of electronic television and also about more inventions of him, which suspiciously looks like the TPU.
http://www.overunity.com/index.php?action=tpmod;dl=item246
Marco.
@Marco
Yes, we were discussing about the system two years ago. I am sorry that you did not found what this phenomena is all about.
The model is developed further and contains now the calculation for needed magnetic field strenght etc. The model explains also, why it is so very difficult to develop and tune TPU only with a quess method.
--Magnon
turbo
wattsup
@marco
Thanks for the doc. Well done. I see the parallels but cannot comment because I do not know enough about it.
@Magnon
Very interesting especially about the toroids being a soft material. May explain why some of the wound wire looked rather embedded into the surface of the toroid. I'll have to think about this further. What frequencies are you talking about.
I tried to look up your profile and there is no permission to do so. Hmmmmm.
Last point is the xlsm file. What do you need to open this file. I'm using Office 97, goes way back, so I think I cannot view that file if it is done for later Excel versions. Can it be exported in other formats like PDF.
Added:
Just noticed you started a new thread on this.  Good idea to not mix threads up.
EMdevices
Steven Mark, in his comunications with Lindsay, talked about the concepts of magnetic fields in the passage below.
I will make some comments at the botom after you read the text.  Here's the text taken from the SM pdf file.  (Note:  just prior to this text he was talking about the Tesla magnetometers all in the context of energy in the magnetic fields of the earth.)
Please let me make another point.
Let us say that you have a magnetic field perhaps it is only a small permanent magnet.
Now, you have a single copper wire twelve inches long.
If you move the magnet across the surface of the wire from left to right at a certain speed you create an electron flow which is DC and it has a power potential based on how strong the field is and how fast the magnet is moved.
So, if you increase the size of the magnet or the speed it moves, you create a larger flow of electrons, larger as in higher voltage or more current.
Everyone tells us that the earth's magnetic field is measured as being too insignificant to generate any useable power, that is not so.
Let me give you something to think about...
If you had a short wire and you moved a magnet across it you would always have limited potential because the length of wire was so short.
OK now what if we increase the length of the wire to many miles in length even with a very weak magnetic field moving across the wire you still have a much greater potential flow of power
available.
If we put it into a perspective of power per inch it may be easier to
understand.
If you have a small magnetic field moving across a wire twelve inches long it can generate an electron flow equal to lets say one millivolt per inch.
If you move the magnet twelve inches at the same speed you get 12 millivolts as you transgress the twelve inches of wire.
Understand that I am trying to convey a principal that you can understand for use in the future.
So, you have a wire twelve inches long and you can make 12 millivolts moving a magnet across it.
If you have a wire 1000 feet long and you move the same small magnetic field across the length of it you can create much more voltage potential perhaps 12,000 millivolts lets say.
So, you have managed to generate a significant amount of electric power with a weak magnetic force.
OK, how does this help us? where am I going with this?
Suppose you have 1,000 pieces of wire twelve inches long and you run the same weak magnetic field over them all at the same time..... you get the same flow of electrons.
If the wires are run in series then you will get the 12,000 millivolts etc.
If you connect the wires in parallel you will get higher current but lower voltage.
However, the power potential is the same whether you run the wires in series or parallel.
If you know how to find the circuit potential, you tune into the frequency and you have enough short pieces of wire you can convert as much power as you wish in a given space.
Things are more complex then what I have told you but I am just trying to
give you an idea of how the technology works.
In a nut shell, we can say that Steven is talking about magnetic induction. Here's a few points.
He mentions a weak magnetic field of the earth and the need to TUNE into it's frequency. This is the most crucial point, he is not talking about the STATIC magnetic field of the earth but about a certain frequency or frequencies.
He mentions possibilities of series or parallel connections of the loops.
He mentions the possibility of faster speeds for this magnetic field that cuts across the wires, and as I showed before this correlates to faster frequencies since v = - N dphi/dt
He also mentions the need to find the circuit potential, so his device might be a bit unconventional such that it is not readily apparent where the voltage potential is occuring.
Over all, we can say his TPUs are primarily magnetic induction loops and together with the capacitors we see, they form tuned LC tank circuits that resonate and couple to the fluctuating magnetic fields, therby extracting energy from them.  He could also be using unconventional methods of creating resonance like vibrations which have higher Q's, but the main principle is using magnetic fields to cause a flow of current in a wire, just like he said in one of the videos as well,  the plain principle of magnetic INDUCTION.
EM
tosky
@WATTSUP
Download from www.openoffice.org install the suite, it replaces Microsoft office and successfully open that file. It is more advance than MS office.
