Towards Realizing the TPU
Started by poynt99, September 03, 2008, 08:46:35 PM
Earl
@Marco
when you apply increasing voltage across a P-N junction, the leakage current increases slowly in a controlled fashion.  At a certain voltage, you arrive at the same condition as in a nuclear reactor without neutron absorbers, namely an uncontrollable chain reaction.
When the avalanche voltage is reached, the voltage gradient is so high that for each electron ripped off an atom, it collides at such high velocity with another atom that it knocks off multiple electrons.  When this happens, the chain reaction starts and with-in picoseconds there are so many electrons at such high velocities that the P-N junction becomes a short-circuit.
This can be an extremely useful process, since this happens much faster than any Tesla spark gap or any mechanical switch connecting a long transmission line to an Edison DC dynamo.
The avalanche effect occurs only in devices that use minority carriers, it does not happen with majority carrier devices such as Schottky diodes; they act as Zener diodes and do not avalanche in a chain reaction.
Regards, Earl
forest
Quote from: EMdevices on February 21, 2009, 09:44:05 PM
Steven Mark, in his comunications with Lindsay, talked about the concepts of magnetic fields in the passage below.
I will make some comments at the botom after you read the text.  Here's the text taken from the SM pdf file.  (Note:  just prior to this text he was talking about the Tesla magnetometers all in the context of energy in the magnetic fields of the earth.)
Please let me make another point.
Let us say that you have a magnetic field perhaps it is only a small permanent magnet.
Now, you have a single copper wire twelve inches long.
If you move the magnet across the surface of the wire from left to right at a certain speed you create an electron flow which is DC and it has a power potential based on how strong the field is and how fast the magnet is moved.
So, if you increase the size of the magnet or the speed it moves, you create a larger flow of electrons, larger as in higher voltage or more current.
Everyone tells us that the earth's magnetic field is measured as being too insignificant to generate any useable power, that is not so.
Let me give you something to think about...
If you had a short wire and you moved a magnet across it you would always have limited potential because the length of wire was so short.
OK now what if we increase the length of the wire to many miles in length even with a very weak magnetic field moving across the wire you still have a much greater potential flow of power
available.
If we put it into a perspective of power per inch it may be easier to
understand.
If you have a small magnetic field moving across a wire twelve inches long it can generate an electron flow equal to lets say one millivolt per inch.
If you move the magnet twelve inches at the same speed you get 12 millivolts as you transgress the twelve inches of wire.
Understand that I am trying to convey a principal that you can understand for use in the future.
So, you have a wire twelve inches long and you can make 12 millivolts moving a magnet across it.
If you have a wire 1000 feet long and you move the same small magnetic field across the length of it you can create much more voltage potential perhaps 12,000 millivolts lets say.
So, you have managed to generate a significant amount of electric power with a weak magnetic force.
OK, how does this help us? where am I going with this?
Suppose you have 1,000 pieces of wire twelve inches long and you run the same weak magnetic field over them all at the same time..... you get the same flow of electrons.
If the wires are run in series then you will get the 12,000 millivolts etc.
If you connect the wires in parallel you will get higher current but lower voltage.
However, the power potential is the same whether you run the wires in series or parallel.
If you know how to find the circuit potential, you tune into the frequency and you have enough short pieces of wire you can convert as much power as you wish in a given space.
Things are more complex then what I have told you but I am just trying to
give you an idea of how the technology works.
In a nut shell, we can say that Steven is talking about magnetic induction. Here's a few points.
He mentions a weak magnetic field of the earth and the need to TUNE into it's frequency. This is the most crucial point, he is not talking about the STATIC magnetic field of the earth but about a certain frequency or frequencies.
He mentions possibilities of series or parallel connections of the loops.
He mentions the possibility of faster speeds for this magnetic field that cuts across the wires, and as I showed before this correlates to faster frequencies since v = - N dphi/dt
He also mentions the need to find the circuit potential, so his device might be a bit unconventional such that it is not readily apparent where the voltage potential is occuring.
Over all, we can say his TPUs are primarily magnetic induction loops and together with the capacitors we see, they form tuned LC tank circuits that resonate and couple to the fluctuating magnetic fields, therby extracting energy from them.  He could also be using unconventional methods of creating resonance like vibrations which have higher Q's, but the main principle is using magnetic fields to cause a flow of current in a wire, just like he said in one of the videos as well,  the plain principle of magnetic INDUCTION.
EM
I disagree about frequency. I read it differently.
IF you know how to find circuit potential THEN you know how to compute REQUIRED circuit frequency input. Then you get EFFECT , which if put onto enough short pieces of wire WILL GENERATE POWER.
It seems very similar to Tesla radiant energy field - there is a power in it , but not usable for our present devices. To convert it into common DC you need COPPER wire as Tesla discovered, because radiant will generate normal DC current inside (?) copper.
This is very symmetrical in Tesla transformer patent .At the generator a coarse copper wire is passing normal oscillating currents, which are converted into radiant flowing on surface of pancake coil inside (secondary). At the step down transformer, the opposite action is taken - primary is pancake coil and secondary - coarse copper wire. Patent no 593138, and all other about wireless transmission of power also.
forest
This is something interesting : http://www.rexresearch.com/nucell/nucell.htm
especially chapter about beta radiation adding energy to LC tank circuit at resonant frequency. It looks so close to secondary emission  in vacuum tubes.
Hmm...could we consider surface flowing electrons as beta radiation ?
I have strange look at resonance ; I imagine a AC wave flowing around circuit and meeting itself at correct phase.The length of circuit matching frequency of current ? Or maybe opposite ? Exact number of waves on wire length ?
wattsup
@tosky
Thanks for the in. I will keep it in mind but not for right now. Too many other things to do. I managed to open the Office 97 file @Magnon pu tup on his new thread but I'm getting errors when running the thing. I'll see about it but for me it is not a strict priority.
@EM
Your last post is why I'm saying multi-strand collectors.
The relationship between the control coils and the rings has to be one of gain. The design of the coils has to be bi-complimentary. If you pulse the ring, the control coil has to receive and if you pulse the control coil, the ring has to receive. I have tested this on both ways and there is coupling potential both ways. This is all a question of how you want to play them. Meaning........
In a regular transformer, you can pulse the primary or the secondary and either way, you will transfert energy to the other.
The energy built up in the TPU is omnipresent. It is not supplied by a capacitor accumulating more energy then it can discharge because capacitors will discharge everything in one shot. It is available in the whole device as part of its continuous function and this is why it can start with practically nothing and build up with gain. This cancels many theories of operation.
But I need to do more testing to find the right looping method.
Just as a side note, here is the exact DC pulse generator I have and am using for many of my tests. In case anyone is in the market for one I think this one will go dirt cheap.
http://cgi.ebay.ca/Agilent-HP-214B-Pulse-Generator-Tested-Working_W0QQitemZ250375724982QQcmdZViewItemQQptZBI_Signal_Sources?hash=item250375724982&_trksid=p3286.c0.m14&_trkparms=66%3A2|65%3A1|39%3A1|240%3A1318
@forest
I really liked the read. I don't think there is any relation to the TPU but it does open ones eyes to other avenues towards OU. Really great. But I won't be playing with radioactive isotopes any time soon.
forest
wattsup
I don't like radioactive material either. I talked about surface electrons maybe acting similarly to beta decay...Secondary emission. Is that electrons party from Mannix king tale ?
