Feedback To Source
Started by nievesoliveras, December 21, 2008, 11:28:28 AM
Low-Q
Hi,
If you spread 7 coils with (360o / 7)o apart, you will get less cogging, and smoother run of the rotor as the 8 mangets on the disc will never pass all coils at the same time. Then you can also let all the coils be connected in series electrically, so you need only one rectifier.
I can make a drawing. But it's late now so I will see if I can do that tomorrow some time.
br.
Vidar
nievesoliveras
Quote from: Low-Q on February 25, 2009, 05:01:09 PM
Hi,
br.
Vidar
Thank you @lowq
You are welcome!
Jesus
Low-Q
A setup like this:
It is not as I previously said, but the main thing is to connect the coils in series. If you have the same timing on the coils, the voltage peak will be greater compared to the loss in the rectifier. This will enhance the efficiency related to voltage - so to speak. But remember that the current flowing through the coils will counterforce the rotation as you are trying to run something with this generator - according to Lenz law. This something is the motor running the flywheel, so the motor will get feedback from the coils, so the break will be reduced. The question is now: How much break is it compared to the energy supplied from the coils to the motor? If the motor determind this energy amount, as it is actually the motor that is supposed to run the flywheel, it is naturally to think that the losses through the coils, rectifier, friction and so on, will eventually halt the system. You never know before you try :)
Br.
Vidar
nievesoliveras
Quote from: Low-Q on February 26, 2009, 08:11:03 AM
A setup like this:
It is not as I previously said, but the main thing is to connect the coils in series. If you have th same timing on the coils, the voltage peak will be greater compared to the loss in the rectifier. This will enhance the efficiency related to voltage - so to speak.
That is a good possibility!
My question is: Will it not generate too much high voltage for just one rectifier to handle it?
I mean each coil in series could amplify the previous voltage.
Jesus
Mk1
@all
I personally think that only one bridge won't work, because the voltage has to go trough the other coils , and that will create back push in the other coils.
