Feedback To Source
Started by nievesoliveras, December 21, 2008, 11:28:28 AM
nievesoliveras
Quote from: lumen on March 14, 2009, 11:40:04 PM
Sketch of how to build you own over-unity generator.
Thank you @lumen!
That is a good idea. But I cant see the point.
Could you be more specific?
Jesus
nievesoliveras
@all
You know that my goal still is the feedback to the source.
I saw two photos of a homemade 1N34 replacement called the cat whisker.
I thought that that, if it works according as stated, could be used to aid the source at keeping charged.
The photos follow:
Jesus
nievesoliveras
@all
I replicated the device and my question is:
Which side is the cathode?
Jesus
lumen
I suppose I should give a little better description of how this works.
This is the process:
1: Magnet approaches iron core (no resistance because the diode to the load allows no load on the coil in that direction)
2: Magnet passes coil to center of iron core where the polarity change in the iron core starts and the voltage in the coil changes direction.
3: With no load on coil the iron fully changes polarity and causes  an attraction as it leaves the iron ( the same pull as when it entered the iron)
4: With load on the coil the polarity change is resisted (lenz law) and the iron does not change polarity fully allowing the magnet to leave the iron with less force that when it entered the iron.
This is true!
It is actually simple to understand once you see it.
nievesoliveras
Quote from: lumen on March 15, 2009, 10:35:08 AM
This is true!
That explanation sounds correct, but only testing it will have the last word on it.
Keep experimenting with it and keep us informed of the results you get with your idea.
If comes out that your idea is the way to go and get the feedback needed I will follow it.
Now I am trying to get energy from the air and use it somehow to aid the joule thief pulse motor to stay alive until the battery fails and die.
Also the results I will have must be disassembled and reassembled again and still do the same results. It must be like that in order that the other members can replicate it with the same results.
Jesus
