Thane Heins Perepiteia.
SkyWatcher123
Hi folks, nice updated test in video Thane. Thanks hydrocontrol for that great expansion on my thoughts of how Thanes device may be working, i figured if we keep it simple and look at the facts of operation were probably pretty close as to the speed up effects function. The only thing that concerns me is that i did make a simple test by holding an air core with 30 guage wire by the rotor as it rotated and it caused lentz drag, now maybe it didnt have enough turns or holding it by hand caused a problem or without a ferromagnetic core the current rise time speed is faster and so more rotor speed is needed. i think i will setup my hugh piggot style air core gen. again, although i will test with same rotors being all same polaritys while of course the air coils are exposed to the high density flux of the opposite rotor magnets attracting. It sure would be nice if aircore works as well but well see.
peace love light   :)
hydrocontrol
Quote from: SkyWatcher123 on April 11, 2009, 10:22:33 PM
Hi folks, nice updated test in video Thane. Thanks hydrocontrol for that great expansion on my thoughts of how Thanes device may be working, i figured if we keep it simple and look at the facts of operation were probably pretty close as to the speed up effects function. The only thing that concerns me is that i did make a simple test by holding an air core with 30 gauge wire by the rotor as it rotated and it caused lentz drag, now maybe it didn't have enough turns or holding it by hand caused a problem or without a ferromagnetic core the current rise time speed is faster and so more rotor speed is needed. i think i will setup my huge piggot style air core gen. again, although i will test with same rotors being all same polarity while of course the air coils are exposed to the high density flux of the opposite rotor magnets attracting. It sure would be nice if aircore works as well but well see.
peace love light   :)
Part of the effect of the core is that it attracts the rotor magnet even through the coil is forming a magnetic field that repels the approaching rotor magnet. The effect of the core helps to cancel the Lenz effect of the coil because of the normal core to rotor magnet attraction. Once the coils magnetic field starts to generate it uses the core to generate a larger repelling magnetic field. This is why the rotor has to be spinning at a certain RPM for the effect to occur. I just watched Thanes newest video and in effect he did what I throwing out in my previous posting of using a elongated coil instead of a round coil. I think if he changes his magnets to NNNNSSSS instead of NNSSNNSS it will produce more of a variance in RPM speed. Tilting the approaching rotor magnets at an angle to the coils or stepping the E fingers distance at increasing values would have the effect of squeezing a tube of toothpaste from the bottom up instead of from the middle evenly down. Tilting the E coil so that the first finger is closer to the approaching rotor magnet and the next finger is slightly further away and the last is even further may also provide the rotor with a better "ride the wave effect". Lots of variable to play with.
Cap-Z-ro
Great observations and ideas hydrocontrol...all it takes is one guy (Thane) to light the fire.
Regards...
aTg
Hi, congratulations on your progress, a question. The speed reaches the rotor on your last experiment is the same, higher or lower than it reaches the magnetic rotor without any friction? I mean, totally free without any coil. Thanks for this doubt cleared.
Pageygeeza
Dunno how seriously you can take this question......  Is it possible to create a single phase AC alternator from just a continual strand of wire?
