MAGNETIC GATE --- Possibly the best yet??
Started by magnetman12003, April 17, 2009, 12:14:35 PM
Low-Q
Quote from: AbbaRue on April 21, 2009, 07:06:41 PM
In the FEG 5-45 you find the Floyd Sweet VTA.
He claims that certain types of magnets resonate at a certain frequency,
and says that frequency can be reprogrammed.
This was the basis of his VTA, he reprogrammed the magnet to resonate at 60 Hz.
Then he tapped 60 Hz power from it and ran regular household appliances with it.
He also stated that at certain times the device wouldn't work at all, indicating that the
magnet was tapping into a source of energy from space,
and the position of the earth, moon, and sun had something to do with it.
If this is true and magnets do resonate at a certain frequency it would explain why some people have
got magnetic motors to work and yet no one else seems to be able to repeat it.
If we could learn how Floyd reprogrammed the magnets we could tap into the energy in different ways.
Floyd would place a new magnet into a large coil he built and would determine the frequency it resonated at.
Then he would reprogram it to a new frequency.
Even if we could figure out how to measure a magnets frequency we could design a system around it.
The one in his video demo was resonating at 12.5 Hz. when he measured it and then he did the reprogramming.
He stated that only certain types of magnets could be used for this.
Here is the video SWEET! ;D :
http://video.google.ca/videoplay?docid=2973947177397458172&ei=mVDuScHDLqCI-gGNuoyCBA&q=Floyd+Sweet+VTA&hl=en
The programming process starts 32 min. into the video.
A resonance system is depending on constant properties of the objects included in the system, in order to sustain the oscillation. If you load it, it will limit the oscillation amplitude and lower the resonance frequency. Try to put a regular pendulum in water, and see what happens. The load the pendulum feel in water will not only break the oscillation, but also alter the resonance frequency to a lower frequency. A oscillating magnet must be something like an electromagnet that is connected to a capacitor. You can have quite small input, but there is high currents flowing through each component. There is however no way such system can run a household alone, as any load will limit the phase delay between the components, and therefor the energy output will collapse immediately.
Convincing speach will not proove OU. And the space energy that this magnets utilize is pure BS, seen from my point of view.
Vidar
robbie47
Why would one like to re-program magnets resonance frequency?
I would think that any resonance frequency could be used here, even 12.5 Hz.
Lightbulbs easily work on that frequency as well.
Or is this about tapping wireless from the 110V grid?
