One magnet no bearing Bedini motor
Started by jonnydavro, March 28, 2009, 04:21:55 PM
Pirate88179
Quote from: xenomorphlabs on April 23, 2009, 07:47:19 AM
Bill: It is impossible to see from this video, but you can check if the edge of your magnet is round or if maybe part of it is broken off. Jonnydavro and myself had a pair of magnets where one of them had the side slightly unrounded and that results in the tumbling "X" movement.
I explain that in my first vid: http://www.youtube.com/watch?v=s18_kZBIOp0
Maybe try another one of these "snake eggs".
The rotation speed is good now, you can go from there nicely !
Xenomorph
Thank you.  Jonny mentioned this to me in a youtube message.  I am going to look for some locally today.  My ends are very blunt and, upon very close examination, are not entirely symmetrical.  No chips or damage.....yet but with these speeds it is only a matter of time, ha ha.  I think I fixed most of my problem by removing the concave surface that, due to the wineglass bottom form, put the surface about a half inch above the top of my coil.  Now with this plate, it is only about .050" above it.  That, and the 12 volts, gave me my speed back.  Thanks for the tips and the help.
Really stupid question here:  Has anyone attempted (you might have to be stupid to try this) to get 2 of these running on the same surface at the same time?  You would think they would just cling together but....their poles are moving so fast...they might not.  of course, this might cause a catastrophic accident but....I may have to try this later.
@ Jonny:
Great idea for the top slave coil man.  I am assuming this operates from the same transistor and circuit as the original coil? (Otherwise, I don't see how it could be synchronized.)  You keep coming up with these ideas...I can't keep up with you.  keep it up.
Bill
xenomorphlabs
@Bill: I had the same insane idea. I guess someone needs to build a 2nd unit and speed the magnet up with 2nd unit and then carefully drop it onto the other dancefloor and then observe if its love at first sight  ;D
I envisioned a catastrophic result too. It can be either boosting the experiment enormously or make them sing like never heard before :D
It seems like all a matter of phase, if two opposing pole sides get close then they will attract, in other case they will push each other away. But there is the circular movement still, so this might push them into a faster rotation or whirl them away from each other.
I am sure some nut will try this one day  ;)
Edit: I am just thinking that Jonny could try this with his slave coil to speed a 2nd magnet up and then somehow drop it to the first magnets lid ? But please make a video of it! :D
EDIT2: I had to do it. I made a little test. When one magnet is rotating the attraction seems to be not that strong. However they were in a 90 degress axial offset.
Video: http://www.youtube.com/watch?v=y6BIsW_5G60
EDIT3: This is a possible way to separate the magnets from sticking together . All in case there is a potential advantage in using 2 magnets at all. I feel it could just double the amp-draw if it works at all.
But who knows hehe
Video: http://www.youtube.com/watch?v=nW8Op6qVAOo
gyulasun
Quote from: xenomorphlabs on April 21, 2009, 05:45:12 PM
Little update:
I use bigger puffer capacitors now to dump into the battery.
Also a different lid that allows a more stable rotation of the magnet.
Video: http://www.youtube.com/watch?v=oFqayiEQpGs
I am wondering if it is wiser to just use one big cap and connect the 4 bridge rectifiers to it ?
Gyula, what would you think is a parallel or serial connection of the rectifiers charging the cap more efficiently?
Hi,
I think you will have less forward voltage drop (hence less loss in the output) if you use the bridges in parallel.
( In case of the series connection, the diode voltage drops would be three times as much I think. )
If you wish to increase the output voltage by summing up the 4 voltages, then you would have to use 4 separate puffer capacitors at each diode bridge's output and connect these capacitors in series.
rgds,  Gyula
jonnydavro
@Bill.The "X"magnet thing is definitely a geometry thing.Some of my magnets are misshaped and not entirely symetrical.These are the "X "spinners but they are very stable so you want both types really to test different things.You just have to buy lots or be very choosy when you go to buy them.
I was looking at your last vid and if you get a good magnet it will stand up for sure as your coil seems to be working fine.One thing i would do though is i would try running on plastic.I use a coffee jar Lid and on top of that i put a thin clear plastic lid.The results are the magnet spins really fast and just makes a whine like a jet engine.You will find it a more pleasant experience and performance may increase as you get a bouncing effect from the hard glass surface as well as the noise.You may have to use two hands to start it as you may not be able to with one hand.You can see the lid i am refering to in the attached vid.
Regarding my slave coil.I am using the standard Bedini master and slave setup so the slave triggers at exactly the same time as the master so there is no conflict there regarding sync. ;)
@ All.Today i tested Comwarrior69's idea of using a darlington transistor instead of an npn and the results were quite interesting.I could get the magnet to maintain rotation on 3mA at 2.9V which is the lowest current draw i have had on a bedini to date.I also found that i could not get as high rpms as i can with an npn so i have asked Comwarrior if he has any suggestions on that.
The transistor i used for this test was a TIP 120.
Here is a vid of the test.Regards jonnydavro.
http://www.youtube.com/watch?v=yp9dWb-XeYc
Pirate88179
@ Jonny:
Thanks for the info on the X wobble.  I have not been able to find any local supplier here in town.  These thing used to be all over the place, but I went to like 10 stores and no one had them.  I may have to order more from online which is where I got the first 2.
I am using plastic for my surface.  That is a plastic dinner plate.  It has a very flat (for plastic anyway) and smooth almost polished surface without any defects.  I can find a way to quiet it down once I get it where I want to be.  In my second video, I have everything turned down...I started to open it up a little just to see if it straightened out with higher rpm and it did not, but it really, really got faster and even though I turned the pots back, it just kept going.  I was afraid in that X spinning mode, it can't take this really high rpm so I had to quickly unplug the battery.  My cat, of course, thought we were under attack from some unknown enemy and ran to hide under the bed.  It is hard to get good lab assistants these days, ha ha.
I think you are exactly right about the symmetry, or lack thereof, as being the defining factor in how these will spin.  Later, I will try errout's advice and mark my ends so I can try the other ends of each mag.  He said he has one that spins exactly like mine on one end, but perfectly straight on the other.  That one sounds like the ideal experimental magnet.  Thanks Jonny.
Bill
