One magnet no bearing Bedini motor
Started by jonnydavro, March 28, 2009, 04:21:55 PM
jonnydavro
@wilby.For it to work,i think both magnets would have to remain in a fixed positions on the lids or they would de-sync.This is a problem with the snake egg as it likes to wander and with the more stable X spinner you would have to find two with the same rotational axis so that would not be easy.Sphere's are certainly worth a try.I think if you made spinning tops you could run them in sockets on the lids so that may keep them fixed in position and you could make two the same.EL-tigre has a  spinning top version at the one magnet bedini thread on energetic forum which might give you some idea'sHope this helps but i like your thinking with the u shaped core/coil.
There is another pole there to exploit so what else can we do with it?
jonnydavro
Hi.I have some N42 20mm x 20mm with 6mm hole  Diametricly magnetised cylinder magnets which i have got for another motor i am working on and i wondered if i could adapt them to work on the one mag bedini and i have and it spins fast.Is what i did was i placed an 8mm ball bearing in the hole as a pivot and it is very easy to start and it triggers the transistor from 8 inches above the coil but it gets even better.I can run multiple rotors at the same time and current draw does not seem to be affected.In the video i am running a snake egg and the N42 cylinder at the same time.I have another N42 and will try and get the 2 N42's going but i thought i would let you know what i have for now.Here are some pics and a vid.Regards Jonnydavro
http://www.youtube.com/watch?v=iTG2U8e6Mdo
Goat
Hi all
A new video of the ball magnet reaching high speeds
http://www.youtube.com/watch?v=HQzpdcQf-Wk&feature=channel_page
Translation of alfacentauro1111 info from video
"Motor magnetico funcionando sin rotor , doble bobina una de señal de trigger y otra de pulso para impulsar el iman bola en su polo creando asi una aceleración, el circuito que se utilizo es el conocido bedini"
"Motor function without magnetic rotor, a double coil trigger signal and a pulse to drive the ball into his magnet pole creating an acceleration, the circuit used is known Bedini"
Paul
WilbyInebriated
Quote from: jonnydavro on May 14, 2009, 09:30:19 AM
very clever jonny, 5 stars
brownsville
Great job Jonnydavro,
I haven't had time to try to get multiple spinners yet. I did try the eggs and can get really close.
I did try a round mag with a top type setup but could not get it to spin up to speed. Will give it a go again soon.
Brownsville
