Howard Johnson Replication Tube Claim
Started by X00013, March 17, 2009, 06:27:33 AM
nyctuber
Quote from: Doug1 on May 15, 2009, 11:06:45 AM
He spent how much??!! How come I can never find customers like that I have lots of stuff i can mark up 1000 percent. I'll even buy him lunch with his first 100k order.
Lol
vonwolf
Quote from: nyctuber on May 15, 2009, 11:04:09 AM
Yes, you're seeing it wrong. Queue has spent $$$. His motivation is to reproduce a functional permanent magnet motor.  Looks like it ain't happening.
   Well he dosn't clearly show how the magnet are positioned so It hard to say if the reproduction is valid.
  There is plenty of yelling and waving of the arm's to go around it's not intended for this one repo, its all over the Net and right here.
  Pete
nyctuber
Quote from: vonwolf on May 15, 2009, 11:22:33 AM
  Pete
Because everyone whines if the entire disk isn't in full view. Take a look at all of his videos, Queue isn't in it to pull a fast one. And I can think of far better ways to get an ego boost than to show the world that you wasted your money and couldn't get it to work.. If this WERE valid, the best possible way to fight suppression would be exactly what's happening, many people showing their efforts in the public domain.
ALFPARTS
Quote from: vonwolf on May 15, 2009, 10:59:44 AM
  No, look at the vid., he shows the 2 stator magnets on the wider flat side of the bar then he sets it on the narrow edge with the stator magnets no where to be found? He didn't splice anything he sets the stator magnets off to the side out of the frame on edge?
   Am I seeing this wrong? The magnets are off to the left of that little wall and the Bar is up on it edge. As far as money, hundred and thousands of dollars? Well I don't know his motivation and that's my point, LOOK AT ME.
Stator mags look a bit too close to each other. Yep, too close.
tournamentdan
WOW,
          I go away for a couple days and everbody goes crazy. I do not know how anybody can not understand TK. From his videos to his comments seem to be dead on. What I can not understand is all the dreamers that can not look at things in a scientific way. What I like to do when theorizing on things is take a piece of paper, and on that paper draw a line down the center. On the left side I write reasons my idea will not work. On the right side reasons why it will.
This next paragraph is the left side.
EDDIE CURRENT BRAKE: people try to explain some magical way that he is able to get around this. It is either the rotor magnets block the stator from getting to the aluminum. Lets not forget the two gaps in between the two groups of magnets, and how about the configuration with the six magnets. I suppose the six magnets flux is creating a forcefield protecting the whole plate. Or that the stator magnet is far enough away from aluminum to affect it. If the stator is strong enough to pull on the rotors they will be strong enough to reach the aluminum.
Next, everybody forgets about the strongest point between two or more magnets. Lets close our eyes and imagine. The strongest point between two magnets is the shortest distance. The shortest distance in mylows motor is a 90 degree angle between the stator and the rotor. Now that point is stronger than any other on his motor. Why you ask?  The strongest point of attraction(shortest distance) between the stator and the first rotor magnet is more than the attraction of the stator and the rest of rotors in line because most of the magnetic flux  of the stator and rotor is pulled together leaving little to none to pull on the next magnet. Do not forget also right beside the attraction pole on the stator is a repelling pole pushing each rotor magnet the wrong way first.
I think for now that is enough on the left side of the paper. Now for the right side................................????????????????????????? I got nothing!!!
P.S.          DAVID COPPERFIELD CALLED ,HE WANTS HIS MAGIC ACT BACK.
I'll see your theory, and raise you mine!!!
