New TPU build
Started by Farrah Day, June 14, 2009, 07:13:39 AM
innovation_station
you all know that 3 stack tpu i built it 2 or 3 times years ago ....
same old thing ...
im not going to argue
mark did you do the 3 freq tpu tooo   and reverise engineer the tpu from some stone carveings ....  no sir you did not !!!
thats ok  the ones that have there tpus know who did it !!
thank you ..
william
btw mark  why dont you try 2 freq ... npn and pnp  then runn it through a sm17!!!
:P
next thing im gonna hear i did not figure out how orbit works and a way to tap it ....
thats ok tooo
cuz dont matter to me anymore ....  i just wanted to help solve the silly riddle
so HOW DOES MPI WORK ....  :D
and since you all want to be kids ... STAY KIDS!!   NO I WILL NOT LEARN YOU BOUT MY TOYS ...  SORRY
TACION IS NOT FOR YOU !!
oh yea for those that forgot i solved G too  whats G NOW .....
but you did it all mark ...
;D
you wearing your enlightenment tesla sheild yet ...  lol  :D
im pretty sure a global release is in store soon  ;)
turbo
Quote from: Mk1 on July 07, 2009, 06:36:08 PM
@marco
Nice build , will we have testing results and a video , you have been at it for quite some time now , you are responsible for spreading most of the tpu info we have , you must know all there is by now ...
Yes it look real nice where are you planing to put the circuit and battery ? to make it compact like SM did.
If he did use a battery , after all a inverter at 12 v should light a 100 watt easy ,don't you think ?
And are you using multiple freq ? how many phase ?
You did so much already , now what you enjoy people running after there tale , or just waiting like most for that proof that actually show it can really be reproduced , yes i remember Otto , be he dose admit he doesn't know everything , he is active in helping .
Marc
Without results yes your tpu looks cleaner or better design , but without data , its nothing more then coil , nothing more then ist , without data they are just picture .
Nothing more then what ist is offering , now everyone chose your side , will faith decide.
Hi
I am currently testing with powerfull deep cycle batteries, but i already noticed it works very well on small batteries too.
When i connected the oscillators, which were fed by a 9volts battery, the fields already started moving.
Then i connected the main battery and it didn't make that much of a diffrence.
There is always room for a few small batteries. :)
There is not really need for inverters to power 100 Watt lightbulbs because the tpu is a high voltage high current device, so it will power lightbulbs directly.
However, most grid designed appliances run on a sine wave and the tpu is not capable feeding those devices, so then a modified sine, or a true sine inverter must be used.
Below you can see the signals i used for the first test.
It is basically 3 phase shifted square waves.
This didn't work out too well and somebody started yelling "capacitors, capacitors" to me.  :)
So i switched in a 330u over each mosfet output stage and it imediatly worked alot better.
But i am still convinced after these tests that, IF IT NEEDS TO GO FAST, THE SIGNALS HAVE TO BE CLEAN.
NOISE WILL SLOW IT DOWN.
So that said, if squares are used there is so much harmonic components, and noise that it cannot go fast.
It is as if any signal other then the needed one poisiones overall performance, lowering maximum velocity.
So if it has to be clean, it cannot have corners.
These tests are only to see what happens at what speed.
Marco.
Small Video:
http://www.overunity.com/index.php?action=downloads;sa=view;down=310
turbo
By the way, these DC-AC inverters are so small these days, they will also fit right into a tpu, making it a wonderfull personal portable power supply. :) :)
Marco.
wattsup
@marco
Connection Hunch:
Each of three phases has an in and an out.
Put all three phase outs together in parallel. Put a capacitor on phase two in and connect other end to phase one in. Then just apply only one sine wave pulse on phase two and three ins.
This will simulate the RV technique using three phases connected Wye and run with only one phase.
wattsup
turbo
Hello Wattsup  :)
I don't think you understand.
I am using pulsed DC.
The AC sine has got field reveral and i don't need that.
I want it to run in one direction only.
Marco.
