Panacea University - Cloud Busting Course -OT
Started by ashtweth_nihilisti, July 23, 2009, 12:14:21 AM
ashtweth_nihilisti
All Scientific circles, not to mention governments who have no previous experience in Orgonomy now have no significant reason to ignore these findings. The public must be informed. Records show that:
1. The experimental evidence was gathered, not by one, but by several well-qualified scientists of unquestionable integrity.
2. The results showed a fully consistent picture of subjective effects, objective biological effects, and measurements employing several physical instruments.
3. Observations of each kind were many and repeated.
4. The results are completely inexplicable in terms of traditional physics.
5. All of these effects can be reproduced TODAY.
The suppressed science of Orgonomy has many beneficial applications for humanity. These include Orgone biophysics, therapy, child raising, social and political theories. Simply put; Orgonomy needs a public face.TODAY there is no justification for ANY institution to deny these findings. There is no justification to continue to refuse to investigate these findings for both an alliance and the therapeutic application of Orgonomy to benefit the public. Orgonomy is much more than cloud busting alone. It can be considered to be more related to a part of biology than of physics.
The term “orgone” was coined by Wilhelm Reich in the early 1940s to describe a form of universal background “radiation” or “energy” that he had discovered. Over the next 14 years he made many significant discoveries of how it functioned in nature and the human body. One of these, in 1952, was his invention of a device he called a "cloud buster". This device was able to drain off stale toxic forms of Orgone (Called deadly Orgone energy or DOR) from the atmosphere and restore normal meteorological behavior to areas afflicted with droughts and other atmospheric problems.Cloud busting is the use of an instrument originally invented by Wilhelm Reich which utilizes “Orgone” energy to facilitate these detectable changes in the weather.
If cloud busting is to be done properly and as originally intended, it must be done only to repair a damaged atmospheric energy field, not to simply independently "make rain". It is not wrong to simply restore the climate to normal (due to counterproductive human activity) and then let nature take its natural course. That is the way cloud busting is intended to be done. Reich wrote about this concept, calling it "atmospheric self-regulation".
Quote- Cloud busting cannot and SHOULD NOT be used to "make rain"; it CAN and SHOULD be used to heal a sick and damaged atmosphere and restore a stagnated atmospheric energy field to normal pulsation. If that is done, rain will happen on its' own. Nobody has to "make" it. -Anon
The intent of cloud busting is to RESTORE NORMAL WEATHER CONDITIONS, not to break rain records. The understanding is that climate deterioration is caused by a build-up of DOR (more information on DOR can be found in the faculty section below). The proper way to do cloud busting is to remove DOR and let the atmosphere return to its normal behavior. The goal of any well-done cloud buster operation is the re-establishment of atmospheric SELF-REGULATION which has been obstructed by DOR. Any other use of cloud busting is malpractice and only adds to the problem of the disruption of normal weather patterns.
Panacea has an interest in validating the SCIENCE of orgonomy in cloud busting to the MAINSTREAM ethos, and to help make faculties and the general public AWARE of the benefit from Reich's original teachings. Our test are only being done to substantiate the teachings SCIENTIFICALLY of Reich,towards a MAINSTREAM AUDIENCE. Main thing is to get it on public record. Reich wanted his research COMPLETELY known.Its time for that moment.
Guys we have collaborated with some genuine cloud busting operators to get the information and tests underway Video's and tests are coming from the Panacea farm.
The course does not make available the plans for cloud busting to any one, if you wish to acquire this SPECIFIC information, you have to show a transparent intent and be QUALIFIED and be able to use the information objectively to benefit the whole movement or heal the atmosphere (it can be dangerous). We will however make the DATA available to ALL.
http://www.panaceauniversity.org/
Cloud Busting (PDF) - added July 23 2009
An Educational method for atmospheric self-regulation using the original teachings of Willhelm Reich Orgone energy discovery. This method is a clean non chemical way to treat drought affected areas plus clear smog and pollution. This document is made available for research purposes only.
Ash
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panacea-bocaf.org
http://www.geocities.com/glorybangla/cqtes.htm
utilitarian
Quote from: ashtweth_nihilisti on July 23, 2009, 12:14:21 AM
Ash
A website is not a university, and a posted PDF is not a "course."
ashtweth_nihilisti
Sorry dood, your wrong, the fact that materiel is taught there justifies it, and read the fine print it states that is why its called a university.
Plus the course has instructional and educational material in it. Plus the way to get to the construction.
for you, your ass should not bother with any thing i post in here. See how you like that.
Ashtweth
