!ST/MK1 PULSE MOTOR/GENERATOR DEVICE...
Started by innovation_station, May 06, 2009, 08:41:42 AM
innovation_station
nice wattaup
look what i posted today  ;D
my new axel for my new pulse motor will have an 18 "2.5" thick plastic rotor with 10 1 x 2" neos... in it  ;D
should i make it start from the first push ...
hummm   i will use gear boxes off of it to turn altonators ... 12dc ...  ;D
got a farm at the beach to power up ...  :)   oooo an EB JT TPU UNIT  would be a kool power source too ...
im gonna build a small unit too to turn this ... for IST NEO ZAP  ARC REACTOR UNIT TOO  ;D
IST!
innovation_station
since i posted part of the motor  this gem came from here is the other part i will use the core for a rotating tpu transformer in fact i will use both showen in the picture..
im only re winding 1 ..  the 30 hp unit ..
ist!
it is the darker grey one in the pic showen both are 3 phase units .. i will remove the laminated core from the houseing ...  i will rewind with verry fine wire many turns to the core in a pulsed config so as it rotates .. i will use 12vdc supply ..  most likely pulsed npn and pnp driveing transistors ..  in between the magic motor gen coils i will wind out put transformers .. all the same length of wire .. so on the on TRANSFORMER on the off colpase collector .. out to many caps ...  build up the charge and run invertors right OFF THE BATCAPS ...  ;D
darn core is probally 150 lbs ..  i could then wind a collector pickup round the core ...  and tap the rmf ...  hummmmm
univirse is the NO LIMITS ..  now this winding should supply some amprage ...  i would tend to think anyhow
