Stanley Meyer replication with low input power
Started by hartiberlin, August 18, 2007, 04:39:57 PM
kinesisfilms
i will
I PROMISE.
but nothing is to be released until it is completed.
everything will be open sourced when finished.
kfox777
I've gone through this thread from start to finish and I have no clue where to even begin. I've read a lot of Stan's work and watched plenty of his video's. I am by no means going to be the one to unlock his fantastic technology so don't all flame me at once. I'm not MIB and hate the fact that this has been suppressed so F-Ing long. I remember being a teen when the news of the water powered car was on every news station and paper. From that day Stan was my hero and it just about killed me to find out he had died trying to free us from the energy mongers. What I have read here is one hell of a roller coaster ride and has me questioning who the real BS spoof is. You can rest assured that they are doing everything in their power to pour propaganda into these forums to lead us astray. In one section everyone's chatting away about the updated Ravi document and to follow it to the "T" but by the time you get to the end all of a sudden Ravi is a spoof "working for the CIA" and all of his work is garbage? Many now agree that it may be a dead end and that the conditioning actually wrecks the tubes but common people... Where the hell do we stand in this fight?
Sorry I'm just frustrated by the back and forth crap that's going on here. Can someone point me in a good direction to start in? Like which circuit I should build and weather or not I should waste my time building the true meyer's demonstration cell? Ravi's tubes were significantly shorter and used 316L instead of the 304 that Stan stated several times. Hell the guy with one 304 tube was getting good results with no conditioning at all... What if it was 9 tubes at 19-20" like Stan's?
Kfox
HeairBear
Well, I would say you have two choices of what you want to build. The Tubular Array/Alternator or the Variable gap/VIC. Both are well documented in the independent study pdf. Both demo cells are rather easy to build with off the shelf parts except for the clear containers, but, you may be able to use an alternative such as a 20x4.5" clear water filter canister. If you feel that finding materials are hard to find or anything like that, I would be more than willing to offer help if I can. Have fun and good luck!
When I hear of Shoedinger's Cat, I reach for my gun. - Stephen Hawking
dankie
Just wait till I'm finished with my HHO experimental driver , for 350$ you will never need any other tool besides copper wire or a lathe maybe, I will be including a 1/4 pound of my s/s wire with it .
It will include my very own super easy to use multi phase delay pwm , it is similar in function to the hex controller . This is not like regular pwm3board , you only choose the main freq with a pot and choose the phasing of  f/2 and f/4 with 2 other pots , the phasing is locked to a small window , it adjusts itself according to the main frew , very intuitive , very easy to use the duty is a constant 50/50 tho :( .... Sorry , too hard to make it otherwise , would have lost the ease of use ...
my perfect 50/50 pulser , the word perfect if not there for no reason , and if you wanna have control over the duty cycle of the main freq just use the wonderful free source jolt circuit ( not included ) wich is like an ideal lawton circuit without the bugs of 2 slave 555 . And hook it up to my perfect signal processing logic for an always smooth start and finish . Its up to you ...
And my pride and joy creation , this thing is quite a unique product , my dc powered solid state alternator wich will be good up to 20khz and good up to 5 amps/ 40 volts . This can be = to any number of alternator you want as much as you have the pnp npn power push-pull transistors and some other slave op amps for driving them. So basicly once you have the driver circuit , you can add infinite numbers of alternators for about 5 $ + the  2 batteries , this is AC folks , you can run any transformer with this as long as the core material keeps up . These will always be perfectly synchronized . The frequency is controlled by any oscillator ( potentimeter ) or any VCO , for future upgrades ( ;D ;D ;D ;D ) , It can be amplitude modulated by simply moving the voltage level on a pot or a wave perhaps ?? (AM ;D ;D ;D) This is as close as it gets to the Xogen Black Box .It is the driver from the Hydroxy refilling patent .
To make this possible I am using state of the art adaptive filtering to keep the sine wave as pure as possible across a wide frequency range  . I had to calculate matched "counter" filters to counter my amplitude drop across . This was done only so you dont have to switch filters or adjust constantly , I am going over  over my way to get this and over the limit and still getting as pure wave same amplitude across 50hz to 20 khz .When I say pure it is pure and 100% noise and transient free !!! This is all powered by DC analog components remember
This does not requires annoying pulleys and high watts/rpm motor . It is much less noisy and messy , I dont know much energy a motor takes to go to 3000 rpm with a 2-3 amp load but this has the same energy requirement at 50 hz and at 20000 hz . The only wasted energy is the energy waste by the transistor and heatsink to form that wave , so about 30% ... But no motor !!!
It will be the smartest buy of 2009 so save up that $ , let your imagination to the rest ...
Right now I'm just lazy trying to get this massive pcb done .
see my youtube
http://www.youtube.com/user/dankiewfc
