Xaverius
Quote from: Rhead100 on September 21, 2009, 07:16:16 PM
Thanks Xaverius ;   Glade I could help. And thanks for the incuragment.
As for the naysayers, those dumb asses would not know fee energy if it hit them in the ass with a board.  Energy IS free.  It's the dang machine that converts it ti useable energy that coasts money.  The wind blows free. But it does not make electicity nor does it grind corn.  Windmills convert it to useable power.
I have said many times,  the 2 stage oscillator does NOT make energy from nothing. AND it is not perpetual.  It will ,  like any wind mill, water damn or coal or gas fired boiler,   need maintanience.  Sombody is going to have to build it.  And somebody is going to have to maintain it.
Damn;;;  Aint life great.  Look at all the new jobs we just created.   OOOHH  shit;; I just used that Nasty,  7 letter word. (CREATED).  Hay;;  Before all you naysayers get all bent out of shape ,  I did not say from NOTHING.   HAHAHAHAHAHAHA.
                       Raymond   RHead100
LOL!!!!  Good points and great attitude!
exnihiloest
...Energy IS free....
Same thing as "Allah is great".
Prove it.
The assertions of "free energy" from subscribers to the grid seem me always very suspicious  :-)))
Rhead100
Just in case anyone is interested. We have started back to work on the 2 stage oscillator and are building the towers to house the escapement mecanisums for the feed back system to try to compleat the loop.
If anyone has any ideas,  I am wide open to suggestions.
http://www.youtube.com/watch?v=s4_wQXJ41ks&feature=channel_page
        Raymond    RHead100
el-tigre
Hi Raymond,
The suggestion I had for an easy build is to fix a piston pump above and below the swing arm and have it pump water into a tank fixed above the pendulum.  Place a trip valve fed from the tank at the end of the pendulum arc and when the pendulum strikes it, the valve will dump an amount of water on the pendulum sufficient to propel it to max swing for another cycle.  This simple method takes care of all timing issues, and you can easily measure your results. If the water level in the tank goes up over time you have demonstrated over unity.  If the level drops, you start again.    This simple rig permits lots of variation in pump size, stroke length etc. etc. to ensure you get maximum output deposited into your holding tank.    I wanted to build this one myself but, sigh, no time this season.  Good luck.
TechStuf
Raymond,  I like your style.  You don't let assumptions get in the way of facts.
You didn't hear this from me, but mounting your pendulum's pivot point on a small, well lubricated trolley can improve your situation considerably.  As your pendulum weight reaches it's zenith at each swing, the trolley can be moved in the 'opposite' direction for a well timed, though nominal fee.  One that is more than paid each time your 'stock' hits the bottom.
Good day and God bless,
TS
“For the wisdom of this world is foolishness before God. For it is written, “He is THE ONE WHO CATCHES THE WISE IN THEIR CRAFTINESS” - 1 Corinthians 3:19
http://www.freemasonrywatch.org/sixpointedstar.html
http://www.youtube.com/watch?v=XBjOs-egFMs
http://www.youtube.com/watch?v=_WSGwnz7XpY
http://www.youtube.com/watch?v=l39XsMcyvgA
http://portland.indymedia.org/en/2004/09/297062.shtml
http://www.youtube.com/watch?v=JjjIy1DO0gs
We all have the choice to waste ourselves in rebellion or to gain wisdom.  Therefore, gain wisdom:
http://www.hisremnant.org/eby/articles/kingdom/twohands/twohandsof.html
