Earth Electrical Energy Datalogging Experiments
Started by Pirate88179, July 14, 2009, 09:40:58 PM
Cosmicfarmer
A stubblefield generator has a zinc bolt core, copper and steel wire bifilar wrap with cotton insulator, and outside of that, is a tertiary winding which a high voltage frequency is applied until the earth becomes entrained.
Check out his patents?
And I don't think you can force an amperage...  If you get an entrained EB or stubblefield your amps can get high but it seems hard to entrain properly.
jeanna
Quote from: Cosmicfarmer on October 22, 2009, 11:34:00 AM
Hi cosmicfarmer,
Correction
No zinc anywhere.
Stubblefield specified soft iron.
No steel either, just soft iron.
freepow I gave some patent info on the stubblefield thread cuz I saw your request there.
jeanna
electricme
@All,
Sorry for this late reply, havent been ignoreing you all, I been in hospital with diverticulitis, as one of my daughters likes to say "my insides hurt" on occasions lol.
I will get back to you all in a moment, but first I need to take a looksee at the web address jeana posted
jim
People who succeed with the impossible are mocked by those who say it cannot be done.
electricme
@jeanna,
Quote from: jeanna on October 20, 2009, 05:16:10 PM
Hi Jim,
I was reading somewhere but I dunno where...
It might only flash one or 2 times per day.
[edit : found it
http://www.overunity.com/index.php?topic=972.msg204504#msg204504
end edit]
Did you leave it in place out there?
I am thinking maybe there was a charge accumulation from all the activity involved in making the cap (I totally love that you made it all!).
Maybe you can set up a buzzer instead of a led. peizo buzzers take next to nothing to cause a sound and you do not need to have your eyes glued to the spot to see its period.
cool... I need to download stuff to watch your vid or else turn on my mac, but I am using this ubuntu computer so I don't need to use the mac here at ou...
thank you for this cool update.
jeanna
Thankyou for your responce, I will endeavor to answer your questions as best I can.
The whole setup I made in the house, on my work bench, the energy I feed to the homemade cap is via a set of extension leads which are connected outside to my EB cells.
How many times a day could I flash a LED with it, well thousands of times, the LED must be removed from the circuit, the capacitor recharged then the leads on the capacitor must be removed and the LED placed across the capacitor to get it to flash.
I might rig up a rotary switch to make it easier to do this.
A charge initailly would have acumulated while I was making the capacitor, but once it was discharged, then there would be no more charge, any other charge would be only supplied via my EBCells.
An pizo buzzer would need a fair amount of energy to be acumulated to make it go beep, at the moment, it only gives a flash for an instant, then it's all gone.
To make it more efficient, I would need to over the, time, current accumulated, energy transferr to device racieo. (I tried for 3 minutes to spell it) lol
jim
:D
electricme
@Cosmicfarmer,
Wow,
Quote from: Cosmicfarmer on October 21, 2009, 01:09:08 AM
Huzzah! rods in a ground I can monitor.  Japan wasn't going to happen, unless I bought a farm for 200 a year, which would be swank and I might do that april... but now I am home in DC ish area.
I got a Carbon and Magnesium.  I forgot which way to position them so I should ask here...
But right now the carbon is northernerly at exactly Latitude = 38.8922, Longitude = -77.1554
and the magnesium is southernerly at Latitude = 38.8920, Longitude = -77.1554, so 1 tenthousandths of a degreee off.
Should I switch their position?
I am letting them entrain over a 1 ohm resistor.
I like circuits that plug into the ground.
I will construct tomorow a camera flash jeul theif. Fuji? I have his cd right here. Then the output will go to Dr Stiffler SEC... and from there a gigantic panel of LED's and I will wake up the neighbors at night...  Oh boy.
I would like a less then 20 volt backspike though, I think the 500 or so volts that fuji gives would fry the Doc's tiny circuit.  I wonder to make a solid state and a frequency counter attached together to make a power supply?  Ah im just dreaming !!
So I got some gigantic supercaps, 3 of em. only a few volts though. Also some of those ultra low volt transistors.  And a lot else.
If anyone has any suggestions in arranging those to obtain the most light, please tell me, while I offer up scope shots of the resistor in my backyard.
Ok so heres the questions all arranged in order.
hello,
1. which one should go north and south? carbon / magnesium
2. any idea on how to charge a cap most efficient from the ground?
3. how to bump 3 volts 650f to ~18 - 20v
4. Anyone know of any Ley Lines around?
thats it,
Hi to Jeanna  thx for sticking in there
peace.
Q1
Magnesium and Carbon rod placements, the best person to ask this Q to would be Bill (pirate88179) he has the best setup I know of to date over on the joule thief forum, but it seems strange how the joule thief stuff pops up here now and then along with other stuff, all seems to be intergrated one way or other.
Bills success far outweighs any of mine, jeanna also is a good source of knowledge in this area with Xee2, IST and others.
Now a gigantic array of LEDs to wake up the neighbours at night, ha ha ha, go for it bro, if you can get this to work, your are off to a good start.
I have been toying with an idea of using several voltage regulators in parallel  to step down a higher voltage to run something, dont know what just yet, got to make up the couple of voltage regulators I bought reciently.
Q2
Charging a cap from energy from the ground, depends on many different factors.
Length of array, depth of electrodes, metals used and amounts.
Each gives out more or less energy.
For instance I can get 60 odd volts out of 83 EBcells, but, it is in uA(micro amps), but, bill gets enough energy out of 1 carbon rod and 1 magnesium bar/rod to light up 500 LEDs.
Now I readon the net, the placement of the EBcells etc, this I am beginning to understand is a critical factor, google earth and a applet attatchment shows me I live in an area where there is almost NO activerty, unlucky me.
I have tried making a aerial power doover, it dosent work at all, I will post it here as the perfect example. The town where I live is between the RED and Blue, unlucky light white/yellow/green lol.
Q3
Bumping 3v to 18 - 20 volts
well a timing arrangement should do this, I have toyed around with this, but couldn't get my head or enough bits together to try it, I made a circuit on the JT topic but no-one picked up on it.
My theory is, have a heep of capacitors being charged and discharged in a continous cycle, it takes time to charge a cap, so you need to work out the charge time, discharge is instant, so can the earth battery recharge a setup of several caps in a second? the faster it can do this the better theoutcome.
A discharge gap spark unlocks the aeather which exposes more energy to play with lol.
Q4
Leylines, now you are talking.
All I need is to see telleric energy flowing through the earth and space my electrodes the width between the leylines, in parallel with them.
The longer the electrodes the more energy I should be able to accumulate.
The trick is to get someone who can devide them using a L wire etc etc, then peg them out, put a peg or marker at where the leylines cross each other.
I must read up a bit more about this topic.
hope this helps you.
PS BELL is the name of a town close to me, the cross is where I live, as you can see, I need to move away from a no energy area to an area that has energy, either to a Blue area or a Red area, but I need to investigate this more.
jim
