Earth Electrical Energy Datalogging Experiments
Started by Pirate88179, July 14, 2009, 09:40:58 PM
tishatang
Here is an idea to try and raise voltage and amps.
Place a parallel resonant circuit that is tunable before the ground rod.  This can probably be made out of an old radio?  Slowly tune across the spectrum and monitor the voltage.   This will raise voltage in the tank circuit when it is in tune to frequencies coming out of the ground.  You could use a scope or freq counter to see what these freq peaks are.  This will raise voltage.
Then connect the same components as a series resonant circuit before the ground rod.  As you tune across the spectrum, at the same freqs you should see a rise in amps.  This should rise the amps.
Try and find one freq that will give you the most volts when in parallel mode and the most amps when in series mode.  The trick will be if we can connect both modes together?  Maybe two sets of ground rods.  One pair wired parallel and one pair wired series and somehow sum them together?
Sorry I am not in a position to experiment myself.  Just offering a suggestion.   You can google resonant circuits to get a picture of what I am talking about between parallel and series resonant mode.
Tishatang
freepow
Hello,  freepow from down under !
I have tried a parallel and series circuit on my Earth battery and also on my antenna+ground connection but did'nt get higher volts or mA with either, my Earth battery running almost North/South, A correction I must make is that my Antenna and ground is actually running East/West and the Sun is currently setting about the same as the antenna line runs,
Here is my full one day graph of volts(AC) and also current (mA) of the output of my Antenna (+) and
ground pipe (-) for today Sunday Oct 25, 2009.
Hope this helps someone to tell me what i am recieving ?
freepow
freepow
Sorry !  Must say one more thing... When I measured my antenna+ground pipe back on Fri 23-Oct, the current peaked unusually high at .2 mA for a about one hour... 1-2 hours before the sun set, yet the current usually peaks at about .13 during the best part of the day.  Why such a spike of current on Fri, I have no idea   :o
Even though it may be such a small amount of current, it still nearlly doubled at one stage on that day,
but the volts stayed at the same level during that reading and also 1-2 hours before and after that reading !
jeanna
MY apologies freepow and anybody else.
I said 265mA and realized later that this should be uA.
The little meter I have has resolutions that catch me.
Your findings are higher than mine by a lot.
jeanna
