New invention of motion less generation of electric power
Started by powercat, August 26, 2009, 08:52:05 AM
Hi Ali,
why don´t you use such a waveform ?
It can be easily generated from a few CMOS
parts or a GAL programmable logic from
6 x 12 Batteries as the source all in series.
Then you would have a + 36 Volts pulse, zero Volts
and -36 Volts pulse.
Would that be okay ?
See attached graphics:
Groundloop
@winsonali,
Here is a proposed circuit that will make a chopped sinus signal at the output.
Groundloop.
Groundloop
@CompuTutor,
Thank you for your comments.
The 4N35 opto coupler has one IR led and one enlarged base IR sensitive transistor inside.
The transistor can be linear controlled by the IR led. See the attached image from the data sheet.
The output of my analog H-Bridge will be a copy of the input signal, providing the amplitude to
the IR LEDs has the correct level so that the opto coupler transistor is controlled as a linear device.
Groundloop.
CompuTutor
I was responding to WinsonAli's request, and it was 4:30'ish AM before my coffee.
I was referencing both Stefan's and your schematic and waveform contributions.
I missed your nick as I was scanning down the page was all,
thought I was reading another Ali post.
I have emptied my above post to correct that.
Sorry 'bout that.
